LOLWingsofGOD said:I take it you dont deliver pizza's for a living...
mcoleg said:1280x720 won't look too great on the lcd this size unless all you do is watch tv or play games. it's good enough... but if you got used to crt, it will look pixelated when you do anything with text. they have another model, 1366 x 768, btw, for 27".
the other monitors resolution's we talking about:
gateway and dell 21" : 1680 x 1050
dell 24" : 1920x1200
westinghouse 37" : 1920 x 1080
now, 1280x720 would probably be fine for most tasks. i can use my 30" olevia just fine as a monitor. just don't feel cheated when everybody's talking about how high a resolution they get and you stack with 1280x720.
Pinky said:I ended up with the 1280x720 westinghouse 27". It really isn't bad at all. My 19" LCD was 1280 resolution, so I'm used to that scaling. What this affords me is DVD viewing from my couch (my setup is a HTPC). The text size isn't too bad, even when viewing it from the computer desk that it sits on. But you're correct that the text is pixelated.
I tested DVD viewing with Finding Nemo, and it was sharp and vibrant. Playback was smooth (no latency issues). Tested UT2004 (since BF2 requires some modification to play widescreen, and wouldn't even run). UT ran very well and I couldn't see any tearing even though it's only a 27" 16ms screen.
mcoleg said:glad it works for you man. at least with 1280x720 you don't need to spend another grand to get your system's speed up to what uber-crazy-high resolution needs .
aznkc730 said:i still think the dells are better.
If you have plugs that are DVI-D, they will accept a DVI-D or DVI-I cable. If you have plugs that are DVI-A, they will accept a DVI-A or DVI-I cable. If you have plugs that are DVI-I, they will accept any type of DVI cable.
