The above post is right as a general info, if you need a more accurate reading, you should get the following data:
1.-Voltage over all the rails of your PSU (you can read them in MBM)
2.-Amperage of each of the above lines. This is the tricky part. I think that your need a multimeter to read this.
3.-Potency factor, when in doubt use 0.8
To calculate to wattage, this will be Voltage*Amperage/Potency factor. Sum this figure for all your rails. This should be your total consumption of your PC.
You need to factor in the consumption of the monitor (this should be on your user manual both the normal and the energy saving readings) and all you peripherials like speakers, printer, etc. The follow the proceadure above described and you should know how much power you are drawing from the grid.....
If this seems to be to much trouble, you can get a wattimeter to can plug between your power surge protector and the electrical installation that should count each and everyone of the system components.
