How do these sandra values look for my system?
FyreDaug
Saskatoon, SK
THIS IS MY RAM said:
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd iSSE2 : 4720 MB/s
RAM Bandwidth Float Buff'd iSSE2 : 4725 MB/s
Results Interpretation : Higher index values are better.
Int Buff'd iSSE2 (Integer STREAM) Results Breakdown
Assignment : 4640MB/s
Scaling : 4638MB/s
Addition : 4805MB/s
Triad : 4798MB/s
Data Item Size : 16 byte(s)
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 70% (estimated)
Float Buff'd iSSE2 (Float STREAM) Results Breakdown
Assignment : 4642MB/s
Scaling : 4642MB/s
Addition : 4810MB/s
Triad : 4807MB/s
Performance Test Status
Run ID : DARKCRESCENT on Wednesday, March 08, 2006 at 7:41:49 PM
Memory Used by Test : 512MB
NUMA Support : No
SMP Test : No
Total Test Threads : 1
Multi-Core Test : No
SMT Test : Yes
Dynamic MP/MT Load Balance : No
Processor Affinity : P0C0T0
Page Size : 4kB
Use Large Memory Pages : No
Chipset 1
Model : ASUSTeK Computer Inc SiS655 CPU to PCI Bridge
Front Side Bus Speed : 4x 210MHz (840MHz data rate)
Width : 64-bit
Maximum Bus Bandwidth : 6720MB/s (estimated)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.5-3-3-8 2CMD
Bank 1 : 512MB DDR-SDRAM 2.5-3-3-8 2CMD
Bank 2 : 512MB DDR-SDRAM 2.5-3-3-8 2CMD
Bank 3 : 512MB DDR-SDRAM 2.5-3-3-8 2CMD
Channels : 1
Speed : 2x 210MHz (420MHz data rate)
Width : 128-bit
Maximum Memory Bus Bandwidth : 6720MB/s (estimated)
MY CPU said:
SiSoftware Sandra
Benchmark Results
Dhrystone ALU : 9733 MIPS
Whetstone FPU : 3866 MFLOPS
Whetstone iSSE2 : 7016 MFLOPS
Run ID : DARKCRESCENT on Wednesday, March 08, 2006 at 7:45:19 PM
NUMA Support : No
SMP Test : No
Total Test Threads : 2
SMT Test : Yes
Threads per Core : 2
Processor Affinity : P0C0T0 P0C0T1
Number of Runs : 64000 / 640
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.20GHz
Speed : 3.36GHz
Performance Rating : PR4469 (estimated)
Cores per Processor : 1 Unit(s)
L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector, 2 threads sharing
Chipset 1
and lastly:
MY CPU MULTIMEDIA said:
SiSoftware Sandra
Benchmark Results
Integer x8 iSSE2 : 23729 it/s
Float x4 iSSE2 : 31575 it/s
Run ID : DARKCRESCENT on Wednesday, March 08, 2006 at 7:47:50 PM
NUMA Support : No
SMP Test : No
SMT Test : Yes
Rendered Image Size : 640x480
Processor
Speed : 3.36GHz
I think the CPU seems a little low scoring.... Could my mobo be a bottleneck? Its a pretty cheap one, actually the cheapest 478 board I could find (after I blew up the p4c800e-deluxe board, I was broke and needed a board)
talked with lowfat on his 3.35 system and my system inches ahead, so it looks like nothings wrong (was concerned somethign was wrong with CPU, and it wasnt working quite right)
