AMD A4-6300 Beginners guide to overclocking
Sundeezl
Hello, I am new to overclocking. I have heard about it and I have researched it but I am still weary of doing it for fear of failure. Please let me know if I can overclock my...
~Core
~Memory
~Graphics
I have...
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD A4-6300
Codename Richland
Specification AMD A4-6300 APU with Radeon(tm) HD Graphics
Package Socket FM2 (904)
CPUID F.3.1
Extended CPUID 15.13
Core Stepping RL-A1
Technology 32 nm
TDP Limit 65.0 Watts
Core Speed 3904.7 MHz
Multiplier x Bus Speed 39.0 x 100.1 MHz
Stock frequency 3700 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
L1 Data cache 2 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Min FID 9.0x
# of P-States 8
Chipset
Northbridge AMD K15 IMC rev. 00
Southbridge AMD A58 FCH rev. 2.6
Graphic Interface PCI-Express
PCI-E Link Width x0
PCI-E Max Link Width x0
Memory Type DDR3
Memory Size 8 GBytes
Channels Single
Memory Frequency 801.0 MHz (1:8)
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 28
Bank Cycle Time (tRC) 39
Uncore Frequency 1601.9 MHz
Memory SPD
DIMM # 1
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Patriot Memory (7F7F7F7F7F0200000000)
Size 8192 MBytes
Max bandwidth PC3-12800 (800 MHz)
Part number PSD38G16002
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
Sundezl, welcome to OCF.
The a4-6300 as far as I can tell has a locked multiplier. So all overclocking would have to be done by the bus and will be limited by the IGP. This also will depend on your motherboard. What board are you using and CPU cooler.
Looks like the A4-6300 is an OEM chip, is it a prebuilt system such as a dell, hp etc...?
Motherboard= MSI A58M-E33
CPU cooler?
I've been reading about "Turbo". Says I can get 3.9Ghz using turbo but I don't know what that is
CPU cooler?
When overclocking you need to add voltage, when doing so it raises the temperature of the Cpu/Apu which you will need to dissipate with an aftermarket heatsink. That said it's a moot point because even if you could OC that Apu I wouldn't even try it on that motherboard.
Turbo is only active in certain circumstances and it's all automatic. CPU cooler is the fan and heatsink that sin on the CPU to help keep it cool. Most likely yours is stock. Before you overclock you might want to run a Prime 95 test and monitor your temps with AMD overdrive.
+1 on the motherboard. It's just not suited to overclocking at all.
I'm looking at CPU-Z and it says My max bandwidth for Memory Slot #2 is PC3-12800 (800 MHz). Isn't this supposed to run at 1600 MHz?
That is 1600 MHz ram DDR is double data rate so 800x2
If it works yes, though you may have to use the motherboard Bios to raise the Gpu clock speed.
Is there a guide for that? And should I do it in small increments? GPU is an AMD Radeon HD8370D. I don't think I can control the fan speed on the GPU
OverClock amd A4-6300
:welcome:
active el ez oc mode a 3900mhz
oc mode manual 107mhz
amd turbo off
amd aplication off
miltiplicador 37.0
voltaje 1.32500
cpu nb frecuency x8.0 1712 mhz
Cool'n'Quiet off
core c6 mode off
igp 1520 mhz
motherboard
FM2A55M-DGS R2.0
fuente generica 500w :(
4Gb de ram a 1333 o 1666 (actualmente 1712 oc)
bios de fabrica :clap:
