- Jan 30, 2008
So, I just moved my system from my Silverstone FT01B into the Corsair 600T (and after using a solid aluminum case for years, steel and plastic feels cheap as hell. But man is it snazzy). My next move which will be soon-ish, is taking the plunge into getting my CPU and GPU under water. Here's the prospective list so far.
Swiftech Apogee HD Ultimate
Either Koolance VID-AR797 or Heatkiller GPU-X3
Swiftech MCR220-XP
Swiftech MCR120-XP
EK DDC X-Res 140
Laing DDC-1T
Those are the main parts. The plan is to have the 120.2 on the top, and the 120.1 on the front, both with some push\pull fans on them. I haven't really dove into the case too much yet, but I might just dremel the top and put a single 120.3 up top instead of the two rads, I'd have to see how it would fit.
Does all that look like it jive's together though? Will the pump be able to handle that loop? Would having a single 120.3 over the 120.2/120.1 provide any kind of advantage? While I'm not expecting extreme temp differences, it should cool both the CPU and GPU better than an H80 on the CPU and stock on the GPU. Just looking for some input and criticism. Thanks
Swiftech MCR220-XP
Swiftech MCR120-XP
EK DDC X-Res 140
Laing DDC-1T
