How does this setup look
McJudge
1x pump eheim 1260 600 GPH $99.99
2x maze4 waterblock for socket tab motherboards $43.95x2=$87.90 (dual cpus)
1x blackice Xtreme radiator $65.99
1x Single 5 1/4 Bay Reservoir $29.95
1x zerex racing super coolant 12 oz $8.50
1x 1/2" y fittings $1.50
1x 3/4" to 2 1/2" y fitting Marine depot $4.69
1x UV water Dye-Lite $8.99
20x 1/2" plastic hose clamps $15.00
2x 3/4" plastic hose clamps marine depot $.99x2=$2.00
2x 1" plastic hose clamps marine depot $1.29x2=$2.58
15ft. tygon 1/2 tubing $20+
3' 1" clear plastic tube marine depot $2.09x3=$6.27
3' 3/4" clear plastic tube marine depot $1.59x3=$4.77
1x fillport clear anodized $11.95
1260 is too hot for its power. Get a D4/mcp650, 50z/mcp600, MD-20RZ, 1250, 1048 or DDC/mcp350 instead.
Swiffy 6k series is much better than maze4, and only slightly more expensive i beleive.
With 2 cpu's I strongly urge you to get a larger rad at least a 240x120mm sized, or another BIX.
Run the blocks in series too.
I would go for stainless steel wormdrive clamps myself. Rather than plastic.
Res and fillport together is redunant aswell. They are both essentially the same thing, and unlike rads and pumps, 2 res' will not increase performance (to a measurable degree for our puposes).
Other than that, yay. Make sure to adjust all your tubing aswell. All those pumps above (except the DDC - 3/8") are 1/2" and dont have a 3/4" inlet (except the 1250 - 5/8") like the 1260/1060.
I would go with some newer waterblocks personally.
If you like the DD stuff, get a couple TDX blocks.
