electrometro
- Oct 5, 2014
Welcome!
This is my first build log so be easy on me.
This build is my first water cooling build and I am very very excited. I am hoping that everything goes super smoothly with the parts I ordered and that it will all come together as planned (I know it probably won't though). I will be re-using most of the computer components from my current build and then when I get the money (probably around the new year) I will be buying much better hardware (x99 baby!). I chose the colors yellow and grey as I plan to go to the asus x99-e ws board and it will all match then and look amazing on top of being a beast of a machine.
Part list and status
All case parts are in gun metal grey.
All parts are ordered unless stated otherwise.
Case:
Case-labs STH10
Case Accessories:
2x 140.4 radiator side mounts
140.3 radiator flex bay mount
Pair of 120mm tube management covers
120mm pump mount
DEMCi Flex Magnetic Dust Fan Filter for 140.3 Flex-Bay
HD Casters
Fans & Radiators:
11x Corsair AF140 Quiet Edition
1x Corsair AF120 Quiet Edition
2x alphacool monsta 560 radiators (ordering soon, waiting for store credit from the black ice radiators)
Pump, Resevour and Blocks:
Alphacool VPP655 Variable Speed Pump HF Top Edition
EK Supremacy EVO Acetal CSQ
EK Radeon HD 7970 Acetal CSQ
Bitspower Water Tank Z-Multi 250 Reservoir
Tubing and Fittings:
PrimoChilll clear 1/2" OD Rigid Acrylic Tube - 4x 24" Pack
10ft of PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD for behind the case routing and draining
4x Bitspower Compression Fitting - Matte Black
Bitspower G1/4" Matte Black T Adapter - for draining
16x PrimoChilll 1/2" OD Rigid Ghost Compression Fittings
Re-used Computer Components:
AMD FX 8350
Asus Sabertooth 990FX R2.0
Gigabyte 7970 OC Windforce
16Gb G.Skill 1866Mhz
2x Crucial M4 128Gb ssd in raid 0
3Tb 7200 RPM HDD
3x Asus 24" Monitors
Misc Items:
5x ModMyToys 5 way 3pin power distribution blocks
3x EK Ekoolant Pastel Concentrate 250mL - Pastel Yellow
Monsoon Hardline Pro Cutting Kit & Heatgun
PrimoChilll 1/2" OD Rigid Tubing Bending Kit
Prolimatech PK-3 Nano Aluminum Thermal Compound
Bitfenix Alchemy Multisleeve Extensions
The log:
Fan Painting
Parts arrived...with bad news
More coming soon
Thanks for looking and I hope you are as excited as I am! I will post up some pictures here soon as I paint the rings on the AF140's
