- Jan 6, 2016
I want to change to a smaller case with external radiators, so I can move the damn thing around (current case is Caselabs TH10A).
In the process, so will I most likely upgrade some parts. Ether right away or over time.
So leaving this here for feedback about parts and how well things play to getter.
Given the high end nature of the build, so do I doubt I can select cheaper parts in many places, but let me know if you think I can.
Case: Corsair Obsidian 750D - Air flow version
MB: MSI X99A GODLIKE carbon
CPU: Intel i7-6950x
GPU: Gigabyte G1 980ti 3 way SLI (1 owned)
RAM: HyperX Predator 2800MHz 64GB (8x8GB)
PSU: Leadex Platinum 2000W (8 Pack) (owned)
Storage: Samsung SM951 NVMe 512GB, Intel 750 NVMe PCIe 400GB, Samsung 850 EVO SSD 1TB x3, Samsung 850 EVO SSD 250GB, WD Black 6TB x4
Cooling:
3x Cougar LED-Fan D14HB-B Blue 140mm
24x Cougar LED-Fan D12HB-B Blue 120mm
4x Scythe Himuro HDD Cooler
2x Phobya Xtreme SUPERNOVA 1080 radiator - Full Copper
2x Phobya Nova 1080 Box - Bricky
2x Phobya Nova 1080 Box faceplate - Bricky
Bitspower MSI X99A GODLIKE GAMING Nickel Plated Full-Covered-Block (Clear)
3x EK-FC980 GTX Ti WF3 - Nickel
3x EK-FC980 GTX Ti WF3 Backplate - Black
EK-FC Terminal TRIPLE Serial - Plexi
2x Laing DDC-pump 12V DDC 3.25 18W
2x Alphacool Eisdecke Laing DDC Plexi top V.2
2x Alphacool Eisdecke DDC/D5 single reservoir for Alphacool Eisdecke top
2x Alphacool Laing DDC metal bottom - black nickel
2x Alphacool Cape Cyclone mounting clips 2 pcs 60mm - black
2x Custom reservoirs (300mm)
aquaero 6 PRO
Passive heat sink for aquaero 6, black
aquabus Y-connector 4 pins
EK-Tube ZMT Matte Black 16,1/11,1mm
EK-ACF Fitting 10/16mm - Blue
Koolance quick release connector G1/4" inner thread to male (High Flow) incl. bulkhead coupling - QD3
Koolance quick release connector 16/10mm (ID 3/8" OD 5/8") female (High Flow) - QD3
CPU: Intel i7-6950x
Cooling:
aquaero 6 PRO
