best case for a pair of twin200mm rads
w1yov5r4on5
im looking for the best case for another build
to support two Phobya Xtreme 400 - 60mm V.2 - Full Copper
each to be paired with one pump an cooling plate
i have a
EK-Supremacy EVO BLUE Edition
https://www.ekwb.com/shop/ek-supremacy-evo-blue-edition
two EK-XRES 140 Revo D5 PWM (incl.pump) - Glass
https://www.ekwb.com/shop/ek-xres-14...-pwm-incl-pump
1 for the cpu an 1 for the gpus
mine are the Gigabyte GeForce GTX 1070 G1 Gaming Graphics Card 8gb
i have 1 im working on buying the other
still looking for a great full cover water cooling plate
my current pick is to be the Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M03 - incl. backplate - Black (11367)
for each but id like something that cools the vram better
my cpu is the AMD RYZEN 7 1800X 8-Core 3.6 GHz (4.0 GHz Turbo) Socket AM4 95W YD180XBCAEWOF Desktop Processor
my motherboard is the ASRock Fatal1ty X370 GAMING X AM4 AMD Promontory X370 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
my ram is a pair of G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16D-32GTZKW
1-CORSAIR RMx Series RM1000X 1000W 80 PLUS GOLD Haswell Ready Full Modular ATX12V &
EPS12V Power Supply SLI and Crossfire Ready
1-TP-Link Gigabit Ethernet PCI-Express Network Adapter (TG-3468)
2-Crucial MX300 2.5" 275GB SATA III 3D NAND Internal Solid State Drive (SSD)
CT275MX300SSD1
2-Seagate IronWolf 10TB NAS Hard Drive 7200 RPM 256MB Cache SATA 6.0Gb/s 3.5"
Internal Hard Drive ST10000VN0004
1-Pioneer Black 16X BD-R 2X BD-RE 16X DVD+R 12X BD-ROM 4MB Cache SATA Blu-ray Burner
BDR-209DBK
12-BitFenix Spectre Pro BFF-LPRO-20025B-RP 200mm Blue LED Case Fan
4-SilverStone PWM Fan Hub Systems
a pair stacked on both sides of each rad
a pair stacked in front for the intake
2-COUGAR CF-V14HB Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 14CM Silent Cooling
Fan (Black) for stacked rear exhaust
i will post photos when fully assembled an i get the best case an gpu cooling plates
About the only one I can think of of hand that they would fit into without major modifications would be something like a thermaltake core x9 or maybe a Mountain Mods case. Do you already have the 400mm phobia rads? If not I would suggest different radiators that will offer similar or better performance and will fit cases better. Neck of you went with the core x9 you could fit 4 x 480 rads if you really wanted to.
