- Apr 26, 2004
- The Netherlands
Hehe...i tricked my ISP.
We have cable broadband at home, and several computers using it through a router. Because Chello, our provider, is increasing the speeds of the connection (4mbps down, 1mbps up), we were given a new modem. This new thingy was supposed to use a dynamic IP instead of the fixed IP we got used to with out old modem.
What wasn't told is that the router support is virtually none - to prevent you from using the internet on multiple computers (officialy denied, but not allowed, however, everybody used to do so). Now when i set up the router for a dynamic IP, the modem simply wouldnt connect to it, so it was 'no internet'
I really wanted the Inet to work on all pcs it worked on previously, so i thought of a way around the dynamic IP. I connected the modem to just one pc (no router), and asked for a dynamic IP. Chello gave it to me (through the router to my pc), and i wrote it down, as well as the other setting (DNS, gateway etc.) Now comes the good part: i set those parameters in the ''fixed IP'' section of the router, and now it works fine!
I asked for a dynamic IP, set that one as static so i can keep using my router and multiple pcs
