How many watts is this CPU ?
DDR-PIII
Disabled
6p6
I've got a crappy systyem ;0 yep from '98, anyway i've also got a CeleronII ? sitting around its a 633Mhz, well ive got a 633 and 600mhz cellys, which would oc better do you think and they arent many watts right ?
also, im gonnapickup a slotket :) so i canrun it in my440bx-2 mobo :) fsb goes from 66mhz - 133mhz :)
Just pull up the Sspec's off the chip and go to Intel and they will tell you what your chip puts out as far as heat goes. I got a good 633 and it runs all day at 950. But unfortunatly not all 633's were created equal so also take a look at the voltage the chip needs if its 1.75 i think then you got a bad one but mine runs offa 1.7 and they will leap over 1ghz if you play with volts.
depending on which model you have and what voltage and speed...
about 13-21 watts without overclock or overvolt
