- Oct 14, 2011
- Southern Indiana
Reading though the Beginners guide several times (and even more times for reference) im debating how how much radiator i need for the loop i want to make. The problem is, the guide only references 120mm size. However with my case (Haf X) I know i can fit a dual 200mm up top.
The main question is, how much does a 200mm rad equal in terms of 120s, and will the 2x200 (or 200.2) be enough to cool an i7 Ivybridge & 2 GPU's? (not i dont have the i7 or dual video cards i want to do this with just yet, but im starting to peice together the WC loop so i dont have to buy it all at once.)
There are a few other places i can put Rads, such as a 200mm spot up front, as well as a 140mm spot in the back (tho im thinking it might not be a good idea to have every exhaust in the case with a RAD on it). So if the dual 200mm wouldn't be enough, would a 2nd, 200mm intake RAD be enough?
I've been reading over that a few times, as well as watching alot of youtube videos on peoples WC setups. (due to the guide, ive been kinda bothered by how many people use dyed water in their loops lol) So ill likely ask alot of questions, Tho i will do my best to not ask any that are covered in the guide or in more recent posts.
Thanks.
Thanks.
