- Sep 26, 2002
- Indianapolis, IN
link for the sp2 download of the dll seems to be dead...
mbentley said:link for the sp2 download of the dll seems to be dead...
MadSkillzMan said:uxtheme.dll for XP SP2!
Ok guys, sorry for the long time in between. I know many of you want to try xp sp2, and find it fixes our little uxtheme.dll hack. Well im here to correct that.
1. Make sure you already installed SP2
2. Go here and download the NEW uxtheme.dll.
http://www.tcmagazine.net/downloadget.php?id=56&file=1&evp=58fed8e77f9276466ed31d9991d1c383
Its a .rar, so you need winrar or winace...etc..
3.Extract it to a temporary directory and rename it from uxtheme.dll TO uxtheme1.dll
4. Copy uxtheme1.dll to C:\Windows\system32
Ok heres the tricky part. We have to boot into the recovery console of the windows XP CD.
5. Insert your windows XP CD, and reboot your computer. Make sure your configured to boot from CDROM. Once you boot into the windows setup, you will be able to choose "Repair an existing installation with recovery console". You press R to get here. So do so.
You will be thrown to a black screen similar to DOS. You will then have to choose which OS, usually its 1., but those of us multibooting have to choose the correct OS.
By NO MEANS do most of the DOS commands work here. DONT MESS AROUND. ONLY follow my steps.
6. At the C:\WINDOWS> type CD system32. This should put you into the folder of C:\windows\system32
7. at the C:\WINDOWS\system32> type ren uxtheme.dll uxthemeA.dll
it might ask a yes or no or confirmation. Tell it yes.
8. At the C:\WINDOWS\system32> , type ren uxtheme1.dll uxtheme.dll
9. At the C:\WINDOWS\SYSTEM32 type EXIT. This will reboot your computer.
Now just reapply your previous themes and there you go!
PM if i have the wrong syntax or anything ill correct it.
MadSkillzMan said:Ur welcome phobmx..lol...im STILL sending people to this thread that arent on the forums...doesnt surprise me u guys still dig it up. glad ya do.
Id like to EMPHASISE!
The packages on Themexp.org, TRY to get the .zip files only...the .exe's contain TONS of spyware!...what i did, was started alittle folder on my D: drive, titled it CUSTOMIZE, and just made 1 big folder of al my themes...that way, when windows decided to be a jerk and require a reinstall, i just copy the files over...no spyware, no buggy loaders..hmm...getting an idea for a program..
MadSkillzMan said:i use a combo of adaware pro and spybot S&D....even if u click NO THANKS it loads u up..friend of mine had 30 objects after one theme install...but, if u do as i suggested, and back them up, next windows install ull be fine
Also, a note on fonts....i have well over 2,000 fonts on my PC...it takes a LONG time to boot it..like bout 3 minutes....i heard, if u place ur fonts in a folder within the fonts, OR, make a shortcut in your C:/windows/fonts, u can still ahve use of them in multimedia progs.....
Now, i have not tested this, YET, but xp is aggervating me like always..a format is comming, so if anyone can vouch for that, lemme know..this works with macs....its how i got the idea...in macs, place them in "My Briefcase "(os9.2)...and u can still use em, but wont slow down ur mac.
