- Nov 16, 2003
- Cleveland OHIO
- Thread Starter
- #61
Im looking into something simpler than litestep, basically turns ur wallpaper into a flash file. Imagine the possabilites
Umm... flash ads on the desktop?MadSkillzMan said:Im looking into something simpler than litestep, basically turns ur wallpaper into a flash file. Imagine the possabilites
Slackfumasta said:Maybe I missed it somewhere in this thread, but is there a DLL patch for SP2? I tried the one for SP1, gave me errors when I tried to change themes.
MadSkillzMan said:I need your opinions!
Ive found something called LiteStep. Completely GPL liscensing. What it does is, replaces eplorer.exe. Basically its a bunch of new shells for windows. Its quite complicated however, but once i learn it i will try my best to teach you guys how to use it. The best thing is, it runs on all win platforms. The other thing is, your windows will remain the same from explorer.exe, but i beleive these can be skinned still the old way.
I was gonna go litestep, simply because thats the first one i saw and you can create your own...but then i saw these other ones. The thing here is, you are going WAY farther than just skinning it. Thing about litestep i liked was you could create your own functions, actions and controls. These others are simpler to install though, but i am not as familiar with them as i am litestep.
Gimme some feedback guys. Thanx in advance.
DrkLrdsSlv said:The visual styles from ThemeXp now come conveniently loaded with Accoona toolbar, just what I wanted No option to just install the visual style, either.
I dont no but windows blinds 5 just came out and it is faster then the normal windows desktop interface.
