- Feb 13, 2007
- Folding in Ames, IA
When running a computer that is dedicated to SETI@home, folding@home, or any other DC project, the goal is to reduce the power consumption to as little as possible. This will not only directly reduce your power costs by drawing less energy, but will also produce less heat, which may save you money as well. Note that computers are not designed to be heaters, and it is more energy efficient to reduce your computer's heat output even if you live in a cold part of the world. Heaters have a much higher heat/watt output than computers do.
The following are steps that you can take to reduce the amount of heat that your computers produce, and energy that they use:
Run your computers headless
Running your computers headless means without a monitor, keyboard, or mouse. If changes need to be made to the computers configuration, they can be done by Remote Desktop over the network.
Remove any unused peripherals
Soundcards, 56k modems, and video adapters all use energy when they're plugged in. Also, you can disable unused onboard peripherals through the device manager in windows, such as firewire, usb, unused network adapters, COM port, and unused IDE/ATA channels. Netword adapters that are in use may have a "power saving mode". Use it if it is available. Turn off your monitor when leaving the room for an extended period of time (thanks Dk Jedi Allianc).
Overvolt intelligently(thanks alexhk)
""Power consumption scales linearly with respect to clock speed. But when you increase the voltage, power consumption increases with the square of the voltage.
i.e. - A 10% increase in core voltage will result in a 21% increase in power consumption.
While performance per watt out of one's CPU is important there is quite a bit of overhead involved in running a rig that can't be avoided. I'm speaking of the power needed for motherboard, RAM, hard drive, ect. I can envision a situation where say 4 more heavily overclocked machines (were overvolted) resulted in more RAC and less power consumption than 5 boxes that were for the most part left alone. I guess the key would be to work out power consumption of the CPU relative to that of the rest of the system and find the sweet spot.""
Buy more efficient parts (thanks Dk Jedi Allianc)
""If you intend to crunch SETI only, better to go with 2 C2D than 3-4 AMD X2. Intel rule for SETI.
If you purchase an AMD X2, go after as much L2 cache as possible.""
Look for power supplies with a higher efficiency rating.
Change your DC client's preferences
For BOINC, set the preferences to write to disk every xx seconds. A larger time will utilize the hard disc less, and thus consume less power, however a computer or power failure will mean more work lost.
Use laptops(thanks freakdiablo)
""Use laptops when possible. 3 of the 4 computers I have running are IBM laptops, and each one only uses 65w, and thats including a core duo T2300 that puts out 950rac.""
(laptops are designed with energy conservation in mind. The fewer watts they draw, the longer the battery will power it, and battery life is something that many, if not all customers look for)
I hope this is helpful! Feel free to post new ideas below and I will add them in up here (with credit to you of course!)
_
_
