- Feb 18, 2002
Over the weekend, a mass of Firefox extensions was wiped out due to incompetence of people in charge.
In 2019 About 10% of Firefox users still used Firefox 52.9 ESR, the final version of Firefox on which many old extensions/Add-ons could still be used on. In May of 2019, many of the old extensions were disabled due to a bug which affected all Firefox versions.
This is the Fix for Firefox 52.9 ESR:
Save the block below including the BEGIN and END lines in a text file with the extension .pem, in other words name the text file something like FirefoxFix.pem
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Tools > Options > Advanced > Certificates > View Certificates > Authorities > Import... > Brose to the saved .pem file and Open it > CHECK every box > OK > OK
type
about:config
in the address bar then paste the name in search box or scroll down to:
devtools.chrome.enabled
Double click on it to set it to True.
Restart Firefox
CTRL+SHIFT+J to get the Browser Console:
Paste these two lines:
Components.utils.import("resource://gre/modules/addons/XPIProvider.jsm");
XPIProvider.verifySignatures();
YOU MUST PRESS Enter AFTER YOU PASTE THESE LINES.
Close all Firefox windows.
In case of problems, simply Disable & then Enable the problem Add-on / extension.
Edited certificate can be seen under:
Mozilla Corporation
signingcal.addons.mozilla.org
type
about:config
Restart Firefox
Mozilla Corporation
