- Apr 16, 2011
Hey there does anyone have experience with Video Rendering is Sony Vegas or video rendering in general? I am using Sony Vegas and I am a bit of a videophile (is that even a thing?). I notice EVERY SINGLE JAGGED PIXEL and it bugs me to no end >.< I want to render a 1080p video it the highest quality possible. The footage I am using is video game footage so there is lots of fine details and motion. Now I am EXTREMELY picky with my video quality. So when I ask if it improves quality, I am talking on a pixel by pixel basis. If it fixes one pixel and adds 1GB onto the file size I still would like to know about it. I am not concerned about file size at all as I have several very large hard drives and don't mind waiting for the video to process. But I still need to edit the footage so it has to be rendered, I can't just use the raw footage from fraps. If there is anything I forgot to say let me know!
1) [SOLVED] Variable bit rate is best yes? I have messed around with it and found the highest I can possible crank it because anything after that seems to lag the video. The bit rate I have set is
Maximum(bps): 240,000,000
Average(bps): 50,000,000
A: The above bitrate is the max and is even recommended as the highest quality by Youtube itself.
2) [SOLVED] Allow the source to adjust the framerate. Is this something I would want? Wouldn't I want it to stay at a consistent 60fps? Or is there something I am missing?
A: Youtube recommends that the source should be the same as the encoded framerate. So yes allow the source to adjust the framerate. It would rather it be at a maximum of 30 however.
3) [SOLVED] The field order. There is upper field first, lower field first, and None (progressive scan). I have it set to None (progressive scan), I read somewhere that results in better quality, but I would love to know why and what it does.
A: Youtube doesn't even support interlacing, it convertes it to progressive when you upload it. So encode it with a progressive scan.
4) [SOLVED] The pixel aspect ration. I think I got this one figured out, 1 is highest quality yes?
A :This is correct, you pretty much always want a 1:1 pixel aspect ration, unless you wanna stretch the video for some reason.
5) [SOLVED] Referance frames. What are these? What would give me the best quality? There is an option next to it that asks if I want to use a deblocking filter, what is this and what would give me the best quality with it?
A: The more the better, it improves quality in moving scenes. Impact to encoding time is minimal, as well as file size increase, so go ahead and crank it up. The max number supported by most codecs is 16.
6) Enabling Progressive Download. I read this has something to do with making it easier to load when it is uploaded, what is it exactly and does it result in a loss of quality?
7) [SOLVED] Probably my biggest question is the Two-Pass option. I understand what it does, it runs through the video once to detirmine the exact needed bit rate and then goes through it again where it actually renders it with that bit rate. But does this result in higher quality footage (even the slightest bit, on a pixel level) with my high bit rate? Seriously if it even fixed those several pixels that make a word look jagged I would like to know.
A: Looking for the BEST of the best? This is it. It is virtualy perfected bit rates. It will fix those itty bitty pixels that are giving you trouble. It is kinda hit and miss on the file size, for higher defenition video it seems to add a bit onto it, but not by enough to worry (several MB). However if you are uploading to Youtube, I wouldn't worry about using this, as any gain that you see here is so small it will be lost to Youtubes video processor. If you really want to use it though, be prepared to wait because it doubles your encoding time.
8) [SOLVED] What are the advantages of different file formats? AVI seems to have a large file size while MPEG4 is smaller. In fact the only reason I am using MPEG4 is because I heard it plays better with youtube. Is there a disadvantage to this file format vs AVI or any others worth mentioning?
A: Youtube's native HD file format is MP4, so it is best to encode it into an MPEG4 so that Youtube does not do a file coversion on your video, resulting in lower quality.
If you actually read that wall of text than congrats! And if you responded than thank you very much!!
