AnimalHungry
- May 3, 2013
First post here, but long time (years!) lurker. I've just upgraded and now have an 8 core CPU and a HD7970 video card that I'm using for some gaming and mining. I have a Thermaltake Tsunami Dream aluminum case which has one fan in front and one behind, as well as the PSU (1000W Corsair) which sucks some hot air out of the case and blows it out the top back of the case.
I'm about to install a Kuhler 620 water cooler to the 7970 GPU and will mount the radiator/fan in the existing rear fan slot below the PSU. What I want to do is get more cool air in there so I was thinking of cutting a hole in the side of my case and mounting a 120mm fan there. However, this side panel is the panel I remove all the time to get inside my case - it has quick release catches and just pops off - so if I mount a fan to it I'll have the fan attached to the side panel and the fan power cable tethering the side panel to the motherboard. This is obviously not ideal, so does anyone have any ideas or pictures (even better!) as to what I should do to avoid the new fan cable tethering my removable side panel to the motherboard? E.g. can you somehow make a bracket to mount the fan to the floor of the case v close to the side panel and then cut a hole in the side panel (covered with wire mesh) to line up with the new fan? Or is that a terrible idea? lol
Cheers
Simon
Cheers
Simon
