How to make these 3 work together? AMD64 X2 6000+, Abit KN9-SLI, DDR2 OCZ Platinum
sebamas
I cant configure the Athlon 6000+ to work right with the DDR2 Memory at 800mhz with the right timings (4-4-4-12). Any clue of why?
CPU-Z 1.39 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Athlon 64 X2 6000+
Code Name Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Package Socket AM2 (940)
Family/Model/Stepping F.3.3
Extended Family/Model F.43
Brand ID 4
Core Stepping
Technology 90 nm
Core Speed 2999.9 MHz
Multiplier x Bus speed 15.0 x 200.0 MHz
HT Link speed 1000.0 MHz
Stock frequency 3000 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA nForce 570 SLI rev. A1
Southbridge NVIDIA nForce 570 SLI rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 375.0 MHz (CPU/8) (Here is part of the problem... I cant set to 800Mhz, and it seems to work only at 750Mhz)
CAS# Latency (tCL) 5.0 clocks (Timings used to be 4-4-4-12, for OCZ Platinum DDR2 2GB Kit)
RAS# to CAS# (tRDC) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Bank Cycle Time (tRC) 22 clocks
Command Rate 2T
System
Mainboard Vendor http://www.abit.com.tw/
Mainboard Model KN9(NF-MCP55 series)
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Date 01/16/2007
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, OCZ
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, OCZ
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
END OF FILE
How should I correctly set them to work perfectly.
I need the processor to work a 3000Mhz, but the memory also at 800Mhz with 4-4-4-12 timings (or maybe its imposible and It can only work a 750Mhz... but how to set timings?)
maybe someone can help.
thanks.
Well first you need to get your setting to 1T. I suggest going into bios and messing with the divider to see if you can get it to cooperate. Also check to see if you need a more updated bios from there site.
he means you Command Rate btw. It can be 1T or 2T. Its set to 2T which improves stability but reduces bandwidth. Switch it to 1T if you can.
Anyway, i would say first up check if the ram voltage is high enough.
If he can't get 2T stable what makes you all think he can run 1T. I've found that above 600 most DDR2 will not run 1T. It may be to RAM, MOBO or Controller.
DDR2 has a DQS setting that you should run when you change ram, change the setting (400/533/667/800) or reset BIOS). Normally this is set to not run but set DQS to enabled or run. When the machine reboots you may see it report the DMI status which at that point it should set itself back to disabled as it only needs to setup once per change.
Other options are a BIOS flash as boards are tweaked from time to time for new ram and newer steppings.
Another option is to run CL5 and overclock the ram by dropping the cpu multi by 1X and running the HTT up to 216. This will run the CPU at 3024 and the ram at DDR2-864 (216x4).
Also look for the HT multi (1X-5X) may be called K8-NB Link or LDT. Set this to 4X.
