- Oct 24, 2003
hey guys, since I noticed a need for some advice and discussion on mining VCT, I figured a separate thread would be best.
I will start with basics:
- VCT doest work on regular cgminer, it needs its own miner found here: http://vertcoin.org/#mining
- however regular cgminer config works and with api-allow enabled, cgwatcher can watch it like a regular cgminer
- note: hashrate for VCT will look half of your normal, that is as it should be
- note: high intensity is not best for VCT, lower your intensity 1-2 points from your normal setup
Cuda miner, sadly I don't have one, but there is some info on the link posted above http://vertcoin.org/#mining
also there are cuda members here and im sure some of them will help if you have issues with yours
happy mining all
update: heres even a calc http://www.verters.com/vertcoin-mining-calculator
thanks Janus for pointing it out to me
happy mining all
