- Dec 16, 2014
Hi,
I'm almost a total noob when it comes to overclocking, so will really appreciate it if someone can please tell me in very simple terms which settings and numbers I should use in BIOS to overclock a 4790K with a Maximus VII Hero motherboard from 4.4 provided by default turbo boost to a manual 4.6 ghz.
Please remember that I'm a noob and that I just want a quick and safe fix, no complicated things. When I had a 3820 I did manage to overclock to 4.6 by following this simple guide:
http://www.overclock.net/a/dummys-guide-to-x79-oc-asus
It would be great if someone has a similar guide which just shows the correct BIOS settings for getting a stable 4.6 using a 4790 with a Maximus VII Hero board.
I'm talking about a step-by-step guide, in the right order of things, like the one above which gives BIOS settings for a 4.6 oc regarding the 3820 in this simple way:
Ai Overclock Tuner: set to 'Manual'
BCLK: set to default, which is 100.000. Do not raise this value over 103.00
CPU Strap: set to 125MHz
Memory Frequency: It is recommended to keep the memory at its rated speeds
Turbo Ration: left it at 'By All Cores'
DRAM Timing Control: default setting for the RAM specifications here. One can also set these settings on 'Auto'.
And so on with the other BIOS settings too.
I'll but anyone a beer if they can provide a similar pedagogic presentation of overclocking the 4790 to 4.6 or 4.7 ghz with a Corsair H75.
