How to overclock my Intel Core 2 Duo E75000
vaibharn
I need a full starting to ending guideto overclock my Processor.
To show my system specs I will simply attach a text document plz read my specs. I am a newbie at things like overclocking .
My basic system specs are:
Intel Core 2 Duo E7500 @ 2.93 Ghz
Dell 018D1Y A00 motherboard
6144 MB RAM DDR3(2 memory modules- First one stock 2 GB ; Second one Transcend 4 GB)
Intel G45/43 Express Chipset (1422 MB)
My CPU is a well ventilated box and it has 3 stock fans.
If you require some additional don't hesitate to ask me and you can also see the text document.
Also tell which software will I need for overclocking my processor.
Thanks
Code:
CPU-Z TXT Report
Binaries
CPU-Z version			1.64.0.x32
Processors
Number of processors		1
Number of threads		2
APICs
Processor 0
	-- Core 0
		-- Thread 0	0
	-- Core 1
		-- Thread 0	1
Timers
	ACPI timer		3.580 MHz
	HPET timer		14.318 MHz
	Perf timer		2.857 MHz
	Sys timer		1.000 KHz
	BCLK timer		266.00 MHz
Processors Information
Processor 1			ID = 0
	Number of cores		2 (max 2)
	Number of threads	2 (max 2)
	Name			Intel Core 2 Duo E7500
	Codename		Wolfdale
	Specification		Intel(R) Core(TM)2 Duo CPU     E7500  @ 2.93GHz
	Package (platform ID)	Socket 775 LGA (0x0)
	CPUID			6.7.A
	Extended CPUID		6.17
	Core Stepping		R0
	Technology		45 nm
	TDP Limit		65 Watts
	Core Speed		1597.9 MHz
	Multiplier x Bus Speed	6.0 x 266.3 MHz
	Rated Bus speed		1065.3 MHz
	Stock frequency		2933 MHz
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
	L1 Data cache		2 x 32 KBytes, 8-way set associative, 64-byte line size
	L1 Instruction cache	2 x 32 KBytes, 8-way set associative, 64-byte line size
	L2 cache		3072 KBytes, 12-way set associative, 64-byte line size
	FID/VID Control		yes
	FID range		6.0x - 11.0x
	Max VID			1.275 V
Thread dumps
CPU Thread 0
	APIC ID			0
	Topology		Processor ID 0, Core ID 0, Thread ID 0
	Type			01008001h
	Max CPUID level		0000000Dh
	Max CPUID ext. level	80000008h
	Cache descriptor	Level 1, D, 32 KB, 1 thread(s)
	Cache descriptor	Level 1, I, 32 KB, 1 thread(s)
	Cache descriptor	Level 2, U, 3 MB, 2 thread(s)
	CPUID
	0x00000000		0x0000000D	0x756E6547	0x6C65746E	0x49656E69
	0x00000001		0x0001067A	0x00020800	0x0C08E3BD	0xBFEBFBFF
	0x00000002		0x05B0B101	0x005657F0	0x00000000	0x2CB43048
	0x00000003		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000004		0x04000121	0x01C0003F	0x0000003F	0x00000001
	0x00000004		0x04000122	0x01C0003F	0x0000003F	0x00000001
	0x00000004		0x04004143	0x02C0003F	0x00000FFF	0x00000001
	0x00000005		0x00000040	0x00000040	0x00000003	0x00022220
	0x00000006		0x00000001	0x00000002	0x00000003	0x00000000
	0x00000007		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000008		0x00000400	0x00000000	0x00000000	0x00000000
	0x00000009		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000A		0x07280202	0x00000000	0x00000000	0x00000503
	0x0000000C		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000D		0x00000003	0x00000240	0x00000240	0x00000000
	0x80000000		0x80000008	0x00000000	0x00000000	0x00000000
	0x80000001		0x00000000	0x00000000	0x00000001	0x20100000
	0x80000002		0x65746E49	0x2952286C	0x726F4320	0x4D542865
	0x80000003		0x44203229	0x43206F75	0x20205550	0x45202020
	0x80000004		0x30303537	0x20402020	0x33392E32	0x007A4847
	0x80000005		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000006		0x00000000	0x00000000	0x0C006040	0x00000000
	0x80000007		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000008		0x00003024	0x00000000	0x00000000	0x00000000
	MSR 0x0000001B		0x00000000	0xFEE00900
	MSR 0x0000003A		0x00000000	0x00000005
	MSR 0x00000017		0x04000000	0xA9848B24
	MSR 0x0000003F		0x00000000	0x00000000
	MSR 0x000000CE		0x00160B24	0x46460712
	MSR 0x000001A0		0x00000040	0x6A972489
	MSR 0x000000EE		0x00000000	0x86790300
	MSR 0x0000011E		0x00000000	0xBE702119
	MSR 0x000000CD		0x00000000	0x80000800
	MSR 0x0000019C		0x00000000	0x88390000
	MSR 0x00000198		0x06160B24	0x06000A22
	MSR 0x00000199		0x00000000	0x00000A22
CPU Thread 1
	APIC ID			1
	Topology		Processor ID 0, Core ID 1, Thread ID 0
	Type			01008001h
	CPUID
	0x00000001		0x0001067A	0x01020800	0x0C08E3BD	0xBFEBFBFF
	MSR 0x0000001B		0x00000000	0xFEE00800
	MSR 0x0000019C		0x00000000	0x883B0000
Chipset
Northbridge			Intel G45/G43 rev. A3
Southbridge			Intel 82801JR (ICH10R) rev. 00
Memory Type			DDR3
Memory Size			6144 MBytes
Channels			Single
Memory Frequency		532.6 MHz (1:2)
CAS# latency (CL)		7.0
RAS# to CAS# delay (tRCD)	7
RAS# Precharge (tRP)		7
Cycle Time (tRAS)		20
Row Refresh Cycle Time (tRFC)	86
Command Rate (CR)		2T
MCHBAR I/O Base address		0x0FED14000
MCHBAR I/O Size			4096
MCHBAR registers
		00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
	00	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	10	00 00 00 80 1F 69 10 00 F7 37 64 DF 00 00 00 00
	20	01 30 03 00 00 00 00 60 00 00 00 00 5A 4A 04 00
	30	86 5A 1F 00 10 28 90 01 00 00 00 F7 10 44 01 65
	40	0A 81 03 8F 00 C0 6B 00 02 00 00 00 00 00 00 00
	50	01 00 80 00 02 01 8F 00 00 00 00 00 00 00 00 00
	60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	55 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	00 00 40 12 00 00 D8 00 00 00 00 00 00 00 00 00
	B0	00 00 D8 00 00 00 00 00 00 00 00 00 00 00 D8 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	100	00 00 00 18 00 00 00 00 00 18 00 00 00 00 00 00
	110	3C 10 00 00 42 99 00 BB 1B 10 7E 81 00 08 7D 00
	120	5F 7F 8D 50 07 E0 3B 40 05 1F 80 00 A0 77 00 5C
	130	A2 FF A9 8F 00 3C A6 29 A5 D2 F2 40 27 D4 D2 40
	140	DF 67 B3 01 9D 87 D3 01 DF 67 B3 01 9D 87 D3 01
	150	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06
	160	99 09 00 00 34 29 30 2B 00 00 00 00 00 00 00 00
	170	00 00 00 00 FF 73 00 00 35 01 00 00 00 FF FF FF
	180	04 0D C8 00 FF FF FF FF 11 B7 0F 0F 00 00 00 00
	190	00 00 01 0E 33 00 00 00 AA AA AA 22 17 2E 00 00
	1A0	01 58 55 00 40 00 00 00 04 00 92 1C FF 40 50 00
	1B0	00 03 00 00 C0 31 00 00 00 00 00 00 02 04 06 08
	1C0	20 03 00 00 00 80 00 00 04 00 00 00 00 00 00 00
	1D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1E0	01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	1F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	200	10 00 20 00 40 00 60 00 86 86 88 88 00 00 00 00
	210	3F 00 7F FF 00 00 00 00 00 00 00 00 00 00 00 00
	220	17 11 00 58 01 02 26 04 02 00 00 00 00 00 00 00
	230	00 00 00 00 00 00 00 00 00 15 00 00 AA 8C 00 00
	240	04 11 00 01 10 23 05 00 33 65 C6 0E 00 33 43 00
	250	99 04 56 F0 88 06 78 74 49 E8 0E 56 10 14 A5 15
	260	E8 3F F7 0B 8A 00 0D 13 EA 4B D0 CF 37 5F 55 03
	270	00 0E 55 01 01 65 08 00 81 18 14 88 41 00 04 48
	280	00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
	290	1C 09 F2 04 95 11 00 00 65 44 00 00 78 07 00 00
	2A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	2B0	00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 00
	2C0	F0 C5 0C 48 7C 01 00 00 00 00 00 00 00 00 00 00
	2D0	00 31 28 FF 00 36 45 40 00 00 00 00 00 00 00 00
	2E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	2F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	300	08 0A 0B 0C 01 02 04 06 00 00 00 00 05 14 04 F0
	310	00 00 00 00 00 00 00 00 00 00 00 00 00 A0 0A 00
	320	00 00 00 00 00 00 00 00 00 00 06 06 06 06 06 06
	330	06 06 07 08 09 0B 0D 0F 11 12 06 06 06 06 06 06
	340	07 08 09 0A 0B 0D 11 15 16 16 06 06 06 06 06 06
	350	06 06 07 08 09 0B 0D 0F 11 12 06 06 06 06 06 06
	360	07 08 09 0A 0B 0D 11 15 16 16 00 00 00 00 00 00
	370	00 00 00 00 00 A0 00 00 CC CC 00 00 00 00 00 00
	380	00 00 05 05 05 05 05 05 05 05 05 06 06 06 07 07
	390	08 09 05 05 05 05 05 05 05 05 06 06 06 07 07 08
	3A0	09 09 01 A0 00 00 66 66 00 00 00 00 00 00 00 00
	3B0	04 04 04 04 04 04 04 04 04 05 06 07 08 08 09 09
	3C0	04 04 04 04 04 04 04 04 05 06 07 08 09 0A 0B 0B
	3D0	01 A0 00 00 66 66 00 00 00 00 00 00 00 00 04 04
	3E0	04 04 04 04 04 04 04 05 06 07 08 08 09 09 04 04
	3F0	04 04 04 04 04 04 05 06 07 08 09 0A 0B 0B 00 A0
	400	00 00 66 66 00 00 00 00 00 00 00 00 34 34 34 34
	410	34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34
	420	34 34 34 34 34 34 34 34 34 34 34 34 00 A0 00 00
	430	66 66 00 00 00 00 00 00 00 00 34 34 34 34 34 34
	440	34 34 34 34 34 34 34 34 34 34 34 34 34 34 34 34
	450	34 34 34 34 34 34 34 34 34 34 36 00 00 00 36 00
	460	00 00 36 00 00 00 36 00 00 00 00 00 00 00 00 00
	470	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	480	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	490	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	4A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	4B0	00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
	4C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	4D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	4E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	4F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	500	34 34 34 34 06 06 06 06 07 07 07 07 08 08 08 08
	510	38 38 38 38 3A 3A 3A 3A 51 51 51 51 61 61 61 61
	520	1A 1A 1A 1A 30 30 30 30 51 51 51 51 32 32 32 32
	530	23 23 23 23 15 15 15 15 27 27 27 27 47 47 47 47
	540	44 55 DB 06 44 55 24 06 44 55 49 06 55 55 00 06
	550	44 55 B6 06 44 55 24 06 55 55 6D 06 55 55 92 06
	560	7A 00 00 00 76 00 00 00 72 00 00 00 7B 00 00 00
	570	79 00 00 00 7A 00 00 00 72 00 00 00 75 80 00 00
	580	62 51 23 00 60 60 22 22 00 00 00 00 13 F5 00 00
	590	55 A9 3C 1E 68 00 00 80 00 33 00 00 00 F0 F1 00
	5A0	50 04 00 12 C0 C0 01 00 C0 C0 01 00 C0 C0 01 00
	5B0	C0 C0 01 00 0E 1E 00 00 0E 1E 00 00 0E 1E 00 00
	5C0	0E 1E 00 00 07 18 00 00 55 A5 54 55 55 A5 54 55
	5D0	55 A5 54 55 55 A5 54 55 0F 62 00 00 80 3F 00 00
	5E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	5F0	FC 07 00 00 00 00 00 00 00 00 54 55 00 00 00 00
	600	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	610	64 07 C8 78 00 00 00 00 00 00 00 00 41 10 00 00
	620	00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 04
	630	00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00
	640	00 11 00 00 00 00 20 00 00 00 80 08 00 11 41 00
	650	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
	660	01 08 00 00 00 00 00 13 42 30 0C 00 30 18 24 00
	670	00 00 55 00 01 00 00 00 82 20 26 08 62 00 04 48
	680	00 00 00 00 00 00 00 00 00 03 07 0F 1F 3F 7F FF
	690	08 0E 02 04 00 00 00 00 00 00 00 00 00 00 00 00
	6A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	6B0	00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 01
	6C0	A0 14 A0 34 02 00 00 00 00 00 00 00 00 00 00 00
	6D0	00 00 1D 35 00 00 00 00 00 00 00 00 02 01 08 04
	6E0	00 00 00 00 02 01 08 04 00 00 00 00 04 02 01 08
	6F0	00 00 00 00 04 02 01 08 00 00 00 00 00 00 00 00
	700	00 00 00 00 00 00 00 00 00 00 00 00 01 08 04 02
	710	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	720	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	730	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	740	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	750	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	760	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	770	00 00 00 00 00 00 00 00 88 88 00 00 00 00 00 00
	780	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	790	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	7A0	00 00 00 00 00 00 88 88 00 00 00 00 00 00 00 00
	7B0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	7C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	7D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	7E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	7F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	800	00 00 88 88 00 00 00 00 00 00 00 00 00 00 00 00
	810	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	820	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	830	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	840	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	850	00 00 00 00 00 00 00 00 00 00 36 00 00 00 36 00
	860	00 00 36 00 00 00 00 00 00 00 00 00 00 00 00 00
	870	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	880	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	890	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	8A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	8B0	00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
	8C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	8D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	8E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	8F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	900	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	910	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	920	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	930	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	940	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	950	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	960	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	970	00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	980	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	990	00 00 00 1F 08 00 00 80 00 00 00 00 FF CF 01 00
	9A0	10 00 00 3F 00 00 00 00 00 00 00 00 00 00 00 00
	9B0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	9C0	00 00 00 00 07 18 00 00 00 00 00 00 00 00 00 00
	9D0	00 00 00 00 00 00 00 00 0E 72 00 00 00 01 00 00
	9E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	9F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A00	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A10	00 00 00 04 00 01 00 00 00 00 00 00 00 00 00 00
	A20	00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00
	A30	18 06 00 44 00 00 00 00 00 00 00 00 00 00 00 00
	A40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A50	00 00 01 00 00 00 00 00 00 00 00 00 90 01 00 00
	A60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A70	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	AA0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	AB0	00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
	AC0	00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
	AD0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	AE0	00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
	AF0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B00	00 00 00 00 00 00 89 00 00 00 00 00 00 00 00 00
	B10	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B20	00 00 00 00 00 00 00 00 89 00 00 00 00 00 00 00
	B30	00 00 00 00 00 00 00 00 00 00 81 00 00 00 00 00
	B40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B50	08 00 08 00 08 00 08 00 08 00 08 00 00 00 00 00
	B60	10 00 00 00 00 00 22 00 00 00 00 5D 5D 00 00 00
	B70	00 00 00 00 41 00 00 18 00 00 00 00 00 00 00 00
	B80	00 01 02 03 04 05 06 07 08 09 0A 0C 0E 11 14 17
	B90	1A 1E 22 26 2A 2E 32 36 3A 3C 3D 3E 3F 3F 3F 3F
	BA0	00 01 02 03 04 05 06 07 08 09 0A 0C 0E 10 12 14
	BB0	17 19 1B 1E 21 24 27 2A 2D 30 33 36 3A 3C 3E 3F
	BC0	45 5F 45 5F 44 5E 43 43 5D 43 5D 00 00 00 00 00
	BD0	21 1E 14 11 51 47 00 00 1E 1E 1E 1E 21 1E 21 1E
	BE0	1C 26 56 BF 00 00 00 00 00 00 00 00 00 00 00 00
	BF0	00 00 00 00 FF FF 12 85 12 12 12 12 12 12 12 12
	C00	40 24 01 00 FF FF FF FF 80 00 00 00 00 00 00 00
	C10	00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00
	C20	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C30	05 00 00 00 00 00 00 00 00 00 00 00 80 C1 00 00
	C40	00 80 00 02 00 00 00 00 00 80 00 00 00 00 00 00
	C50	05 03 03 05 FF FF 00 00 13 00 00 00 00 00 00 00
	C60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C70	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C80	01 01 01 01 00 00 00 00 00 00 00 00 24 00 03 00
	C90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	CA0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	CB0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	CC0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	CD0	01 01 01 01 00 00 00 00 01 00 00 FF 00 00 00 00
	CE0	00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00
	CF0	00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
	D00	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D10	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D20	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D30	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D50	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D70	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DA0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DB0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DC0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DD0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DE0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	DF0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E00	00 00 00 00 00 00 00 00 40 00 04 00 C4 01 00 01
	E10	00 32 22 00 00 00 00 00 00 00 00 00 00 00 00 00
	E20	00 00 00 00 00 00 00 00 00 00 00 00 C0 6D A9 01
	E30	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E50	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E60	F0 0F 00 00 00 F0 00 00 0F 00 00 00 00 00 00 00
	E70	00 00 00 00 00 00 14 00 20 F0 00 01 00 00 00 00
	E80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	E90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	EA0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	EB0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	EC0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	ED0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	EE0	00 00 00 00 00 00 00 00 00 00 E3 10 00 00 00 00
	EF0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F00	3C 3B 3A 39 40 3F 3E 3D 3C 3B 3A 39 40 3F 3E 3D
	F10	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F20	FF FF FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
	F30	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F40	00 00 00 00 00 00 00 00 E0 FF F0 FF 00 FF C0 FF
	F50	00 F0 00 FC 00 80 00 C0 00 00 00 00 00 00 00 00
	F60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
	F70	FF FF FF 0F FF 7F 00 00 00 00 00 00 00 00 00 00
	F80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	FA0	02 00 00 00 C2 00 91 21 00 D4 30 00 00 00 10 40
	FB0	25 D0 00 10 42 C8 00 00 00 00 00 00 0F F0 00 00
	FC0	80 40 13 80 44 22 E2 0F 00 00 00 00 00 00 00 00
	FD0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	FE0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	FF0	00 00 00 00 00 00 00 00 00 00 E0 2F 00 00 00 00
Memory SPD
DIMM #				1
	SMBus address		0x50
	Memory type		DDR3
	Module format		UDIMM
	Manufacturer (ID)	Nanya Technology (7F7F7F0B00000000)
	Size			2048 MBytes
	Max bandwidth		PC3-10700 (667 MHz)
	Part number		NT2GC64B8HC0NF-CG
	Serial number		28F41061
	Manufacturing date	Week 32/Year 10
	Number of banks		8
	Nominal Voltage		1.50 Volts
	EPP			no
	XMP			no
	AMP			no
JEDEC timings table		CL-tRCD-tRP-tRAS-tRC @ frequency
	JEDEC #1		6.0-6-6-17-23 @ 457 MHz
	JEDEC #2		7.0-7-7-20-27 @ 533 MHz
	JEDEC #3		8.0-8-8-22-30 @ 609 MHz
	JEDEC #4		9.0-9-9-25-34 @ 685 MHz
DIMM #				2
	SMBus address		0x51
	Memory type		DDR3
	Module format		UDIMM
	Manufacturer (ID)	Transcend Information (7F4F000000000000)
	Size			4096 MBytes
	Part number		JM1333KLN-4G
	Serial number		0009D34B
	Manufacturing date	Week 06/Year 13
	Number of banks		8
	EPP			no
	XMP			no
	AMP			no
DIMM #				1
SPD registers
	00	92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00
	10	69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 82 05
	30	00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
	70	00 00 00 00 00 83 0B 0D 10 32 28 F4 10 61 06 A1
	80	4E 54 32 47 43 36 34 42 38 48 43 30 4E 46 2D 43
	90	47 20 00 00 83 0B 00 00 00 00 20 00 00 00 00 4D
	A0	4D 31 30 38 30 37 30 44 45 44 4E 54 30 33 32 42
	B0	35 38 33 00 00 00 00 02 4E 55 00 34 45 00 00 00
	C0	00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00
	D0	00 80 00 00 00 00 00 00 00 00 00 80 00 00 00 11
	E0	00 00 00 00 00 02 00 00 00 03 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 88
DIMM #				2
SPD registers
	00	92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
	10	69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05
	70	00 00 00 00 00 01 4F 54 13 06 00 09 D3 4B 2A F0
	80	4A 4D 31 33 33 33 4B 4C 4E 2D 34 47 20 20 20 20
	90	20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	33 4D 50 33 33 33 2D 41 50 35 35 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 04
	F0	00 46 10 E0 CB 4E D8 4C 32 00 00 00 00 00 00 AB
Monitoring
Mainboard Model		018D1Y (0x00000167 - 0x00432D20)
LPCIO
LPCIO Vendor		ITE
LPCIO Model		IT8720
LPCIO Vendor ID		0x90
LPCIO Chip ID		0x8720
LPCIO Revision ID	0x8
Config Mode I/O address	0x2E
Config Mode LDN		0x4
Config Mode registers
	00	00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
	20	87 20 08 00 00 10 FF 00 01 00 3F 00 03 00 00 00
	30	01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	0A 10 0A 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space		LPC, base address = 0x0A10
Hardware Monitors
Hardware monitor	ITE IT87
	Voltage 0	1.10 Volts [0x45] (CPU VCORE)
	Voltage 1	3.07 Volts [0xC0] (VIN1)
	Voltage 3	5.13 Volts [0xBF] (+5V)
	Voltage 4	4.48 Volts [0x46] (+12V)
	Voltage 5	-8.58 Volts [0x86] (-12V)
	Voltage 6	-8.58 Volts [0x86] (-5V)
	Voltage 7	5.00 Volts [0xBA] (+5V VCCH)
	Voltage 8	3.25 Volts [0xCB] (VBAT)
	Temperature 0	54°C (129°F) [0x36] (TMPIN0)
	Temperature 1	43°C (109°F) [0x2B] (TMPIN1)
	Fan 0		489 RPM [0x564] (FANIN0)
	Fan 1		985 RPM [0x2AD] (FANIN1)
	Fan PWM 0	0 pc [0x0] (FANPWM0)
	Fan PWM 1	0 pc [0x0] (FANPWM1)
	Fan PWM 2	50 pc [0x40] (FANPWM2)
	00	11 10 FF 00 00 00 00 00 00 80 6A CF 07 65 AD 00
	10	FF FF FF 33 D7 82 81 40 05 02 00 FF FF FF FF FF
	20	45 C0 00 BF 46 86 86 BA CB 36 2B C5 80 F7 54 54
	30	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	40	FF FF FF FF FF FF 5F 74 2D 40 95 00 FF FF FF FF
	50	FF 10 7F 7F 7F D0 00 00 90 00 0B 12 60 00 00 00
	60	9C D4 7F 25 A0 03 00 FF 9C 2F 7F 32 98 02 00 FF
	70	7F 7F 7F 00 00 60 00 FF FF FF FF FF FF FF FF FF
	80	00 00 00 00 00 00 00 00 02 30 01 02 01 00 E0 40
	90	FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
	A0	C5 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	B0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	C0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	D0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	E0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	F0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PCI Devices
Description			Host Bridge
Location			bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x2E20
	Revision ID		0x03
	PI			0x00
	SubClass		0x00
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps class		Vendor Dependant
	Caps offset		0xE0
PCI registers
	00	86 80 20 2E 06 00 90 20 03 00 00 06 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
	40	01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
	50	00 00 50 03 19 00 00 00 00 00 00 00 00 00 00 00
	60	01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
	70	00 00 00 00 00 00 00 00 01 08 00 00 00 00 00 00
	90	10 11 11 00 00 33 33 00 60 00 6B 00 00 1A 38 00
	A0	60 00 00 1B 00 00 00 CE 00 00 E0 CD 00 00 E0 CD
	B0	00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 03 03 00 00 60 66 66 13 00 00 19 01
	E0	09 00 0C 21 20 01 A7 8C C2 8D 2F 81 00 00 00 00
	F0	00 00 00 00 08 00 00 00 A6 0F 05 00 00 00 00 00
Description			VGA Controller
Location			bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x2E22
	Revision ID		0x03
	PI			0x00
	SubClass		0x00
	BaseClass		0x03
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFE400000
	Address 2 (memory)	0xD0000000
	Address 4 (port)	0x0000DC00
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps class		Message Signalled Interrupts
	Caps offset		0x90
PCI capability
	Caps class		Power Management
	Caps offset		0xD0
	Caps version		1.1
PCI capability
	Caps class		0x13
	Caps offset		0xA4
PCI registers
	00	86 80 22 2E 07 04 90 00 03 00 00 03 00 00 80 00
	10	04 00 40 FE 00 00 00 00 0C 00 00 D0 00 00 00 00
	20	01 DC 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 90 00 00 00 00 00 00 00 00 01 00 00
	40	09 00 0C 21 20 01 A7 8C C2 8D 2F 81 00 00 00 00
	50	00 00 50 03 19 00 00 00 00 00 00 00 00 00 00 CE
	60	00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	05 D0 01 00 0C 30 E0 FE B0 49 00 00 00 00 00 00
	A0	00 00 00 00 13 00 06 03 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 BC 01 00 00
	D0	01 A4 22 00 00 00 00 00 00 00 00 00 00 01 02 00
	E0	00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
	F0	24 00 03 00 00 00 00 00 A6 0F 05 00 E4 E0 D6 CD
Description			Display Controller
Location			bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
	Vendor ID		0x8086
	Model ID		0x2E23
	Revision ID		0x03
	PI			0x00
	SubClass		0x80
	BaseClass		0x03
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFE900000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0xD0
	Caps version		1.1
PCI registers
	00	86 80 23 2E 06 00 90 00 03 00 80 03 00 00 80 00
	10	04 00 90 FE 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00
	D0	01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	24 00 03 00 00 00 00 00 A6 0F 05 00 00 00 00 00
Description			USB Controller (UHCI)
Location			bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x3A37
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 4 (port)	0x0000D880
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x10
	Int. Pin		0x01
PCI capability
	Caps class		0x13
	Caps offset		0x50
PCI registers
	00	86 80 37 3A 05 00 90 02 00 00 03 0C 00 00 80 00
	20	81 D8 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
	50	13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
	60	10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 86 0F 04 00 00 00 00 00
Location			bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
	Vendor ID		0x8086
	Model ID		0x3A38
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 4 (port)	0x0000D800
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x15
	Int. Pin		0x02
PCI capability
	Caps class		0x13
	Caps offset		0x50
PCI registers
	00	86 80 38 3A 05 00 90 02 00 00 03 0C 00 00 00 00
	20	01 D8 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00
Description			USB 2.0 Controller (EHCI)
Location			bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
	Vendor ID		0x8086
	Model ID		0x3A3C
	Revision ID		0x00
	PI			0x20
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFEAFA000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x12
	Int. Pin		0x03
PCI capability
	Caps offset		0x50
	Caps version		1.1
PCI capability
	Caps class		Debug Port
	Caps offset		0x58
PCI capability
	Caps class		0x13
	Caps offset		0x98
PCI registers
	00	86 80 3C 3A 06 00 90 02 00 20 03 0C 00 00 00 00
	10	00 A0 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
	50	01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
	60	20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0
	70	00 00 CF 0F 00 00 00 00 00 00 00 00 00 00 00 00
	80	00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
	90	00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
	D0	00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 88 85 40 00 86 0F 04 00 0A 17 02 20
Description			Multimedia device
Location			bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x3A3E
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x04
	Cache Line		0x08
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFEAF4000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x16
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.1
PCI capability
	Caps offset		0x60
PCI capability
	Caps class		PCI Express
	Caps offset		0x70
	Device type		Root Complex Integrated Endpoint Device
	Port			0
	Version			1.0
	Link width		0x (max 0x)
Extended capabilities
	Caps class		Virtual Channel
	Caps offset		0x100
	Caps class		Root Complex Link Declaration
	Caps offset		0x130
	Link Entries #		1
	Port Number		15
PCI registers
	00	86 80 3E 3A 06 00 10 00 00 00 03 04 08 00 00 00
	10	04 40 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
	40	01 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00
	50	01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
	60	05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
	C0	00 04 00 01 00 00 00 00 31 00 A3 02 00 00 00 00
	D0	61 00 A3 02 00 00 00 00 00 00 00 00 00 00 00 00
	100	02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
	110	00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
	120	80 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
	130	05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Description			PCI to PCI Bridge
Location			bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x3A40
	Revision ID		0x00
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x08
	Latency			0x00
	Header			0x81
PCI header
	Primary bus		0x00
	Secondary bus		0x01
	Int. Line		0x11
	Int. Pin		0x01
PCI capability
	Caps offset		0x40
	Device type		Root Port of PCI-E Root Complex
	Port			1
	Version			1.0
	Physical slot		#0
	Presence detect		no
	Link width		0x (max 1x)
PCI capability
	Caps offset		0x80
PCI capability
	Caps class		Subsystem Vendor
	Caps offset		0x90
	SubVendor ID		0x1028
	SubSystem ID		0x0439
PCI capability
	Caps offset		0xA0
	Caps version		1.1
	Caps offset		0x100
	Caps offset		0x180
	Link Entries #		1
	Port Number		1
PCI registers
	00	86 80 40 3A 04 01 10 00 00 00 04 06 08 00 81 00
	10	00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 20
	20	F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 40 00 00 00 00 00 00 00 11 01 06 00
	40	10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 01
	50	40 00 01 10 60 05 00 00 00 00 00 00 00 00 00 00
	80	05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	0D A0 00 00 28 10 39 04 00 00 00 00 00 00 00 00
	A0	01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00
	E0	00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00
	100	02 00 01 18 00 00 00 00 01 00 00 00 00 00 00 00
	110	01 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
	120	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	130	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 28 (0x1C), function 2 (0x02)
Common header
	Vendor ID		0x8086
	Model ID		0x3A44
	Revision ID		0x00
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x08
	Latency			0x00
	Header			0x81
PCI header
	Primary bus		0x00
	Secondary bus		0x02
	Int. Line		0x12
	Int. Pin		0x03
PCI capability
	Caps offset		0x40
	Port			3
	Version			1.0
	Physical slot		#0
	Presence detect		yes
	Link width		1x (max 1x)
PCI capability
	Caps offset		0x80
PCI capability
	Caps offset		0x90
	SubVendor ID		0x1028
	SubSystem ID		0x0439
PCI capability
	Caps offset		0xA0
	Caps version		1.1
	Caps offset		0x100
	Caps offset		0x180
	Link Entries #		1
	Port Number		3
PCI registers
	00	86 80 44 3A 07 01 10 00 00 00 04 06 08 00 81 00
	10	00 00 00 00 00 00 00 00 00 02 02 00 E0 E0 00 00
	20	B0 FE B0 FE F1 FD F1 FD 00 00 00 00 00 00 00 00
	30	00 00 00 00 40 00 00 00 00 00 00 00 12 03 06 00
	40	10 80 41 01 00 80 00 00 00 00 11 00 11 2C 11 03
	50	40 00 11 30 60 05 00 00 00 00 48 01 00 00 00 00
	A0	01 00 02 C8 00 01 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x3A34
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 4 (port)	0x0000D400
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x17
	Int. Pin		0x01
PCI capability
	Caps class		0x13
	Caps offset		0x50
PCI registers
	00	86 80 34 3A 05 00 90 02 00 00 03 0C 00 00 80 00
	20	01 D4 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Location			bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
	Vendor ID		0x8086
	Model ID		0x3A35
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 4 (port)	0x0000D080
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x13
	Int. Pin		0x02
PCI capability
	Caps class		0x13
	Caps offset		0x50
PCI registers
	00	86 80 35 3A 05 00 90 02 00 00 03 0C 00 00 00 00
	20	81 D0 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
Location			bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
	Vendor ID		0x8086
	Model ID		0x3A36
	Revision ID		0x00
	PI			0x00
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 4 (port)	0x0000D000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x12
	Int. Pin		0x03
PCI capability
	Caps class		0x13
	Caps offset		0x50
PCI registers
	00	86 80 36 3A 05 00 90 02 00 00 03 0C 00 00 00 00
	20	01 D0 00 00 00 00 00 00 00 00 00 00 28 10 39 04
Location			bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
	Vendor ID		0x8086
	Model ID		0x3A3A
	Revision ID		0x00
	PI			0x20
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFEAF8000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x17
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.1
PCI capability
	Caps offset		0x58
PCI capability
	Caps class		0x13
	Caps offset		0x98
PCI registers
	00	86 80 3A 3A 06 00 90 02 00 20 03 0C 00 00 00 00
	10	00 80 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x244E
	Revision ID		0x90
	PI			0x01
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x01
PCI header
	Primary bus		0x00
	Secondary bus		0x03
	Int. Line		0xFF
	Int. Pin		0x00
PCI capability
	Caps offset		0x50
	SubVendor ID		0x1028
	SubSystem ID		0x0439
PCI registers
	00	86 80 4E 24 07 01 10 00 90 01 04 06 00 00 01 00
	10	00 00 00 00 00 00 00 00 00 03 03 20 F0 00 80 22
	30	00 00 00 00 50 00 00 00 00 00 00 00 FF 00 06 00
	40	00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
	50	0D 00 00 00 28 10 39 04 00 00 00 00 00 00 00 00
Description			PCI to ISA Bridge
Location			bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
	Vendor ID		0x8086
	Model ID		0x3A16
	Revision ID		0x00
	PI			0x00
	SubClass		0x01
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0xE0
PCI registers
	00	86 80 16 3A 07 00 10 02 00 00 01 06 00 00 80 00
	40	01 08 00 00 80 00 00 00 01 05 00 00 10 00 00 00
	60	8B 85 8A 8F D0 00 00 00 80 8E 83 87 F8 00 00 00
	80	00 00 0F 14 01 0A FC 00 00 00 00 00 00 00 00 00
	A0	B4 06 00 00 09 00 01 00 13 1C 0A 24 00 03 00 C0
	B0	00 00 F0 00 00 00 00 00 00 00 00 08 00 00 00 00
	D0	33 22 11 00 67 45 00 00 C0 C0 00 00 02 00 00 00
	E0	09 00 0C 10 01 00 C4 02 64 02 00 00 00 00 00 00
	F0	01 C0 D1 FE 00 00 00 00 86 0F 04 00 00 00 00 00
Description			IDE Controller
Location			bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
	Vendor ID		0x8086
	Model ID		0x3A20
	Revision ID		0x00
	PI			0x8F
	SubClass		0x01
	BaseClass		0x01
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (port)	0x0000CC00
	Address 1 (port)	0x0000C880
	Address 2 (port)	0x0000C800
	Address 3 (port)	0x0000C480
	Address 4 (port)	0x0000C400
	Address 5 (port)	0x0000C080
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x13
	Int. Pin		0x02
PCI capability
	Caps offset		0x70
	Caps version		1.2
PCI capability
	Caps class		0x13
	Caps offset		0xB0
PCI registers
	00	86 80 20 3A 05 00 B0 02 00 8F 01 01 00 00 00 00
	10	01 CC 00 00 81 C8 00 00 01 C8 00 00 81 C4 00 00
	20	01 C4 00 00 81 C0 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
	40	07 A3 03 A3 00 00 00 00 05 00 01 01 00 00 00 00
	50	00 00 00 00 F0 50 00 00 00 00 00 00 00 00 00 00
	70	01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
	80	05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	00 3C 03 83 93 01 00 00 00 00 00 00 00 00 00 00
	B0	13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description			SMBus Controller
Location			bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
	Vendor ID		0x8086
	Model ID		0x3A30
	Revision ID		0x00
	PI			0x00
	SubClass		0x05
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFEAF2000
	Address 4 (port)	0x00000400
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x0A
	Int. Pin		0x03
PCI registers
	00	86 80 30 3A 03 00 80 02 00 00 05 0C 00 00 00 00
	10	04 20 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
	20	01 04 00 00 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 00 00 00 00 00 00 00 00 0A 03 00 00
	40	01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	02 04 04 00 F0 00 08 08 00 00 00 00 00 00 00 00
	80	04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description			Ethernet Controller
Location			bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x10EC
	Model ID		0x8168
	Revision ID		0x03
	PI			0x00
	SubClass		0x00
	BaseClass		0x02
	Cache Line		0x08
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (port)	0x0000E800
	Address 2 (memory)	0xFDFFF000
	Address 4 (memory)	0xFDFF8000
	Subvendor ID		0x1028
	Subsystem ID		0x0439
	Int. Line		0x00
	Int. Pin		0x01
PCI capability
	Caps offset		0x40
	Caps version		1.2
PCI capability
	Caps offset		0x50
PCI capability
	Caps offset		0x70
	Device type		PCI-E Endpoint Device
	Port			0
	Version			2.0
PCI capability
	Caps class		MSI-X
	Caps offset		0xAC
PCI capability
	Caps class		Virtual Product Data
	Caps offset		0xCC
	Caps class		Advanced Error Reporting
	Caps offset		0x100
	Caps offset		0x140
	Caps class		Device Serial Number
	Caps offset		0x160
PCI registers
	00	EC 10 68 81 07 04 10 00 03 00 00 02 08 00 00 00
	10	01 E8 00 00 00 00 00 00 0C F0 FF FD 00 00 00 00
	20	0C 80 FF FD 00 00 00 00 00 00 00 00 28 10 39 04
	30	00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
	40	01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
	50	05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
	70	10 AC 02 02 C1 8C 28 00 10 50 10 00 11 3C 07 00
	80	00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
	90	00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
	A0	00 00 00 00 00 00 00 00 00 00 00 00 11 CC 03 80
	B0	04 00 00 00 04 08 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
	100	01 00 01 14 00 00 00 00 00 00 00 00 30 20 06 00
	110	01 20 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
DMI
DMI BIOS
	vendor			Dell Inc.
	version			A06
	date			12/01/2010
	ROM size		1024 KB
DMI System Information
	manufacturer		Dell Inc.
	product			Inspiron 560s
	version			00
	serial			G9JQ6BS
	UUID			{4C4C4544-0039-4A10-8051-C7C04F364253}
	SKU			0
	family			0
DMI Baseboard
	vendor			Dell Inc.
	model			018D1Y
	revision		A00
	serial			..CN7509306P0409.
DMI System Enclosure
	chassis type		Desktop
	chassis serial		G9JQ6BS
DMI Processor
	manufacturer		Intel
	model			Intel(R) Core(TM)2 Duo CPU     E7500  @ 2.93GHz
	clock speed		2933.0 MHz
	FSB speed		266.0 MHz
	multiplier		11.0x
DMI Port Connector
	designation		SATA 0 (internal)
	designation		SATA 0 (external)
DMI Port Connector
	designation		SATA 1 (internal)
	designation		SATA 1 (external)
DMI Port Connector
	designation		SATA 2 (internal)
	designation		SATA 2 (external)
DMI Port Connector
	designation		SATA 3 (internal)
	designation		SATA 3 (external)
DMI Port Connector
	designation		USB1 (internal)
	designation		USB1 (external)
	port type		USB
	connector		Access Bus (USB)
DMI Port Connector
	designation		USB2 (internal)
	designation		USB2 (external)
	port type		USB
DMI Port Connector
	designation		USB3 (internal)
	designation		USB3 (external)
	port type		USB
DMI Port Connector
	designation		USB4 (internal)
	designation		USB4 (external)
	port type		USB
DMI Port Connector
	designation		USB5 (internal)
	designation		USB5 (external)
	port type		USB
DMI Port Connector
	designation		USB6 (internal)
	designation		USB6 (external)
	port type		USB
DMI Port Connector
	designation		USB7 (internal)
	designation		USB7 (external)
	port type		USB
DMI Port Connector
	designation		USB8 (internal)
	designation		USB8 (external)
	port type		USB
DMI Port Connector
	designation		USB9 (internal)
	designation		USB9 (external)
	port type		USB
DMI Port Connector
	designation		USB10 (internal)
	designation		USB10 (external)
	port type		USB
DMI Port Connector
	designation		VIDEO (internal)
	designation		VIDEO (external)
	port type		Video Port
	connector		DB-15 female
DMI Port Connector
	designation		AUDIO (internal)
	designation		AUDIO (external)
	port type		Audio Port
DMI Port Connector
	designation		ETHERNET (internal)
	designation		ETHERNET (external)
	port type		Network Port
	connector		RJ-45
DMI Extension Slot
	designation		PCI1
	type			PCI
	width			32 bits
	populated		no
DMI Extension Slot
	designation		PCIEX16
	type			A5
	populated		no
DMI Extension Slot
	designation		PCIEX2
	type			A5
	populated		no
DMI Extension Slot
	designation		PCIEX1
	type			A5
	populated		no
DMI OEM Strings
	string[0]		www.dell.com
DMI Physical Memory Array
	location		Motherboard
	usage			System Memory
	correction		None
	max capacity		8192 MBytes
	max# of devices		4
DMI Memory Device
	designation		DIMM0
	format			DIMM
	type			unknown
	total width		64 bits
	data width		64 bits
	size			2048 MBytes
DMI Memory Device
	designation		DIMM1
	format			DIMM
	type			unknown
	total width		64 bits
	data width		64 bits
	size			4096 MBytes
DMI Memory Device
	designation		DIMM2
	format			DIMM
	type			unknown
DMI Memory Device
	designation		DIMM3
	format			DIMM
	type			unknown
Graphics
Number of adapters		2
Graphic APIs
API				Intel I/O
Display Adapters
Display adapter 0
	Display name		\\.\DISPLAY1
	Name			Intel(R) G45/G43 Express Chipset
	Codename		Eaglelake
	Technology		65 nm
	Memory size		1422 MB
	PCI device		bus 0 (0x0), device 2 (0x2), function 0 (0x0)
	Vendor ID		0x8086 (0x1028)
	Model ID		0x2E22 (0x0439)
	Performance Level	0
Display adapter 1
	Memory size		1422 MB
	PCI device		bus 0 (0x0), device 2 (0x2), function 1 (0x1)
	Model ID		0x2E23 (0x0439)
	Performance Level	0
Win32_VideoController		AdapterRAM = 0x58E7F000 (1491595264)
Software
Windows Version			Microsoft Windows 7 (6.1) 32-bit  Service Pack 1 (Build 7601)
DirectX Version			11.0
Can I get some different ways to overclock because my BIOS doesn't have any such option to change frequencies or anything like that.
Uh oh, you're on a Dell. Chances of overclocking that system just reduced to very close to zero. Your only option is SetFSB, which isn't easy and probably won't work anyway.
Your other choice may be a pin mod, but I'm not sure if you can even pin mod an E7500 successfully.
I really hate to say it, but the likelihood of a successful overclock on that system is slim to zero. :(
No problem.
I want to upgrade my motherboard in which I can overclock please also tell some good cooling parts .
Can you tell me some other good grapic cards because my graphic card is ****.
It has fixed dedicated graphic memory of 64MB!!!!!
But please tell all in budget.
My budget is $350.
Honestly, at this point you would have a large amount of trouble finding a good 775 motherboard. You would definitely need a new PSU as well.
What I would recommend is saving another $250, for $600 total. More is better of course, but that amount could build you a decent setup that will run circles around your current system.
$109.99 shipped. Perhaps I should have phrased that differently. It would be a wiser investment to buy something new around that price than get a years old board for a years old chip. If you're going to bench 775 chips for fun, that might be a decent investment. If you're looking for a replacement board for a 24/7 system, that's a gamble. At least IMHO.
Thanks for the reply!
But there is a problem I live in India that's why I can't do online shopping from all the sites.
So , if you have any information about good motherboards which are available on Flipkart.com or eBay India please imform me.
Thank you
I couldn't understand anything which you said above because I am very new to these things.
In future please suggest the best motherboard in my budget.
My budget is upto $500(max).
My aim to overclock is to do perfect gaming!
Thanks
Sorry, you'll have to figure out the getting-from-India problem. I have no idea what the exchange rate is and can't help by linking to those places since I have no idea how much we're talking about. What I can do is suggest parts that you then find in India. My suggestion for your budget is an AMD socket FM2 motherbord with an A85X chipset, plus an AMD APU (accelerated processing unit - a CPU with a GPU built-in) and the rest of the stuff necessary to build a system around it. Again, these are in US dollars, but hopefully the exchange is somewhat similar.
ASRock FM2A85X Extreme4-M - $90
AMD A10-5800K APU - $130
----For a bit more power, I would go with the AMD A10-6800K - $150
Cooler Master Hyper 212+ - $30
Mushkin Blackline DDR3-1600/9-9-9-24 - $65 or Corsair Vengeance DDR3-1600/9-9-9-24 - $65
Seagate 1TB HDD - $70
Corsair CX500M - $60
Windows 7 Home Premium x64 - $100
Total: $545 (or $565, depending on which APU)
You'll have to go just slightly over-budget (and slightly more to get a case), but that is a solid system and will do better and last longer than pretty much anything you could do to your current system for $500.
Thanks for the advise!
I will try to find those items and a perfect case for those!
Thanks
Prices are 25% higher if you want warranty. But you can pretty much get all the same parts. Although some are harder to find. You need the factory warranty service valid in india which is why you buy it locally. US warranty from like amazon and tiger etc are not valid in other countries. Also unlike Ebay.us, Ebay.in is priced much higher than other places. Also import costs 50% more due to freight charges so getting those hard to find parts are not worth it. Always swapping for a similar item even if slightly more expensive or with less features are cost effective. Parts sold as scrap in the US and resold very cheap usually are just sold for like a 25% discount in India Like the 64GB kingston v100 for $50. So are old stocks like sony play stations and sega dreamcasts for around $100. They must sell those because I keep seeing ads for them.
http://www.deltapage.com/list/index.html
Lots of specialized computer stores like delta around, prices are much better than consolidated sites like amazon/junglie etc.. Use Google to find them. Shops like delta also sells via ebay etc but they also add in extra costs for buying from there.
Dump your board! The board probably has an unprogrammable clockgen! :mad:
(That means even the SetFSB program and the like can't help you.)
