I am trying to overclock my NVIDIA GeForce 6800 GS card. Can anyone tell me how to go about doing this and what program to use? Here are my specs per CPU-Z:
Code:
CPU-Z TXT Report
Binaries
CPU-Z version 1.54
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 5000+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
Package Socket AM2 (940)
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
Core Speed 2612.1 MHz
Multiplier x FSB 13.0 x 200.9 MHz
HT Link speed 1004.6 MHz
Stock frequency 2600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 13.0x
Max VID 1.350 V
P-State FID 0x2 - VID 0x12 (5.0x - 1.100 V)
P-State FID 0xA - VID 0x10 (9.0x - 1.150 V)
P-State FID 0xC - VID 0x10 (10.0x - 1.150 V)
P-State FID 0xE - VID 0x0E (11.0x - 1.200 V)
P-State FID 0x10 - VID 0x0C (12.0x - 1.250 V)
P-State FID 0x12 - VID 0x0A (13.0x - 1.300 V)
K8 Thermal sensor yes
K8 Revision ID 6.0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002008h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00060FB2 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00060FB2 0x000008D9 0x0000011F 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x32582034 0x61754420 0x6F43206C 0x50206572
0x80000004 0x65636F72 0x726F7373 0x30303520 0x00002B30
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000007F
0x80000008 0x00003028 0x00000000 0x00000001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000002
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC001001E 0x00000000 0x00000060
MSR 0xC0010015 0x00000000 0x02000040
MSR 0xC0010042 0x31081208 0x08120212
MSR 0xC0010041 0x00000001 0x00000812
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02002008h
CPUID
0x00000001 0x00060FB2 0x01020800 0x00002001 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
Chipset
Northbridge NVIDIA MCP61 rev. A3
Southbridge NVIDIA MCP61 rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 373.2 MHz (CPU/7)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 23
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number CM2X2048-6400C5
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-13-15 @ 270 MHz
JEDEC #2 5.0-5-5-18-22 @ 400 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 30 03 02 00 03 37 50 00 00 32 1E 32 2D 01
20 18 25 05 13 3C 1E 1E 00 00 37 69 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 F1
40 7F 7F 9E 00 00 00 00 00 01 43 4D 32 58 32 30 34
50 38 2D 36 34 30 30 43 35 20 20 20 20 20 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 1F FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
Monitoring
Mainboard Model M2N-MX SE Plus (0x0000041B - 0x759ADCD0)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8712
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8712
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 12 08 11 00 01 3C 17 00 00 01 00 06 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.47 Volts [0x57] (CPU VCORE)
Voltage 4 12.67 Volts [0xC6] (+12V)
Voltage 8 3.04 Volts [0xBE] (VBAT)
Temperature 0 40°C (103°F) [0x28] (TMPIN0)
Temperature 1 31°C (87°F) [0x1F] (TMPIN1)
Temperature 2 128°C (262°F) [0x80] (TMPIN2)
Fan 0 3000 RPM [0xE1] (FANIN0)
00 19 10 FF 03 00 00 00 00 00 80 40 09 03 E0 FF 00
10 FF FF FF 37 87 7F 7F 7F 00 FF 00 FF FF FF FF FF
20 58 FF CA FF C6 61 FF FF BE 28 1F 80 EC F2 F2 F2
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF 2D FF FF FF FF FF FF FF
50 35 18 7F 7F 7F 00 56 56 90 56 F9 12 E0 00 00 00
60 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
70 7F 7F 7F 00 00 7F FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 FF FF FF FF 00 00 FF CA 02 00 99 99
90 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor AMD Athlon 64 X2 5000+
Temperature 0 45°C (112°F) [0x123] (Core #0)
Temperature 1 43°C (109°F) [0x11D] (Core #1)
Hardware monitor NVIDIA GeForce 6800 GS
Temperature 0 46°C (114°F) (GPU Core)
PCI Devices
Description RAM Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0x44
Caps revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0xDC
Interface type MSI Mapping
PCI registers
00 DE 10 EA 03 06 00 B0 00 A1 00 00 05 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 34 82
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
40 43 10 34 82 08 DC 20 02 20 00 11 11 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0D 03 00 00 00 7F 00 00 00
90 70 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
E0 00 00 E0 FE 00 00 00 00 07 00 00 00 20 10 00 00
F0 F0 FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E0
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000900
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 E0 03 0F 00 A0 00 A2 00 01 06 00 00 80 00
10 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 43 10 34 82 00 00 D0 FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 05 2F 00 3C 01
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 FF FF C5 80 00 00 00 00 45 19 00 00 00 40
80 09 80 00 80 0D 12 00 00 00 00 40 01 FF 00 00 00
90 FF 7F 00 00 00 00 00 00 21 65 08 74 B9 0C 00 D0
A0 00 00 10 81 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 30 02 AF 02 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 50 40 00 FE FD 03 00 B0
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03EB
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000E00
Address 4 (port) 0x00000600
Address 5 (port) 0x00000700
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x0A
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 EB 03 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 06 00 00 01 07 00 00 00 00 00 00 43 10 34 82
30 00 00 00 00 44 00 00 00 00 00 00 00 0A 01 00 00
40 43 10 34 82 01 00 02 C0 00 00 00 00 00 00 00 00
60 01 05 00 00 01 08 00 00 01 0D 00 00 00 00 00 00
70 00 00 00 00 00 00 C8 FE 00 00 FE FE 01 20 00 00
80 00 10 FE FE 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 40 00 40 01 10 00 00 00 05 00 00 00 00 00 00 00
E0 88 10 04 00 04 40 00 07 80 22 04 20 41 44 44 11
F0 02 FF 1E BF 01 00 00 80 10 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03F5
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 F5 03 00 04 A0 00 A2 00 00 05 00 00 80 00
40 43 10 34 82 00 00 00 00 10 02 80 10 10 00 10 10
50 10 10 10 10 00 00 00 00 00 00 00 00 10 42 00 00
60 0B 00 00 00 C0 1C 52 06 21 00 10 0A 00 00 63 00
70 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 40 00 00 00 00 00 A0 18 00 00
90 00 00 00 00 00 00 00 12 20 81 04 00 00 00 00 00
A0 00 14 00 06 00 00 00 00 00 00 00 00 01 00 00 00
B0 00 00 00 00 42 80 30 04 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F1
Revision ID 0xA3
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDDEFF000
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 F1 03 06 00 B0 00 A3 10 03 0C 00 00 80 00
10 00 F0 EF DD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
40 43 10 34 82 01 00 02 FE 00 00 00 00 00 00 00 00
50 0E 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F2
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDDEFEC00
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x14
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 F2 03 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 EC EF DD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
40 43 10 34 82 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 83 12 0F 01 00 00 00 00
70 00 00 08 00 00 10 20 80 89 3D B6 22 77 25 54 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 44 00 00 00 FF 00 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F3
Revision ID 0xA1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB8
SubVendor ID 0x1043
SubSystem ID 0x8234
PCI capability
Caps offset 0x8C
PCI registers
00 DE 10 F3 03 07 04 B0 00 A1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
40 00 00 73 07 01 00 02 00 07 00 00 00 00 00 48 00
50 00 00 00 00 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 06 00 00 FC FF 0D 00 00 00 00 00 08 00 01 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 43 10 34 82
C0 43 10 34 82 03 00 00 00 00 00 00 00 00 00 00 00
Description Multimedia device
Location bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F0
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDDEF8000
Subvendor ID 0x1043
Subsystem ID 0x8290
Int. Line 0x17
Int. Pin 0x02
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x50
PCI capability
Caps offset 0x6C
PCI registers
00 DE 10 F0 03 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 80 EF DD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 90 82
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 02 05
40 43 10 90 82 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 03 A8
F0 00 00 00 00 00 00 00 47 00 29 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EC
Revision ID 0xA2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 EC 03 05 00 B0 00 A2 8A 01 01 00 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 43 10 34 82
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 43 10 34 82 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 20 A8 DF 00 20 FF
60 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
Description Bridge device
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EF
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xDDEFD000
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x6C
PCI registers
00 DE 10 EF 03 06 00 B0 00 A2 00 80 06 00 00 00 00
10 00 D0 EF DD 01 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 01 14
40 43 10 34 82 01 50 02 FE 00 01 00 00 08 00 00 20
50 05 6C 86 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 FF 00 00 00 08 00 03 A8
F0 00 00 00 00 00 00 00 00 42 01 00 00 00 00 00 00
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000E400
Address 1 (port) 0x0000E080
Address 2 (port) 0x0000E000
Address 3 (port) 0x0000DC00
Address 4 (port) 0x0000D880
Address 5 (memory) 0xDDEFC000
Subvendor ID 0x1043
Subsystem ID 0x8234
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps offset 0xB0
PCI capability
Caps offset 0xCC
PCI registers
00 DE 10 F6 03 07 00 B0 00 A2 85 01 01 00 00 80 00
10 01 E4 00 00 81 E0 00 00 01 E0 00 00 01 DC 00 00
20 81 D8 00 00 00 C0 EF DD 00 00 00 00 43 10 34 82
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 03 01
40 43 10 34 82 01 B0 02 00 00 00 00 00 00 00 00 00
50 2F 68 08 00 00 00 00 00 00 00 00 20 40 00 00 20
60 00 00 00 C7 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
80 00 00 00 40 00 60 F9 11 00 00 5C 84 7C C7 FB F7
90 00 00 BE 3E 00 00 00 00 06 00 06 10 00 00 01 01
A0 08 00 00 0F 80 00 00 00 00 00 00 00 33 31 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 03 A8
D0 08 00 00 77 00 08 03 00 08 00 00 43 00 08 08 00
E0 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E8
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8234
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
PCI registers
00 DE 10 E8 03 07 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 00
20 F0 DD F0 DF 01 C0 F1 CF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1A 00
40 0D 48 00 00 43 10 34 82 01 50 02 F8 00 00 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 A2 49 00 00
60 08 80 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 01 3D 11 00
90 00 00 01 31 80 25 08 00 C0 01 48 01 00 00 00 00
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8234
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
PCI registers
00 DE 10 E9 03 04 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 92 49 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 00 00 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8234
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 82 49 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 11 3C 11 02
90 00 00 11 10 00 05 18 00 C0 01 00 00 00 00 00 00
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 1.02
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 01 00 E4 00 00 00 20 C8 2E 0F 2C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 07 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 3F 01 00 00 00 00 00 00 00 00
80 03 00 E0 00 80 FF EF 00 00 00 00 00 00 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 C0 00 00 0B FE 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00
F0 01 40 00 C0 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 00 80 00 00 00 00 00 00 00 00 00
60 E0 3F 78 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 46 00 00 00 00 00 00 00
80 05 00 00 00 00 00 00 00 24 F2 7C 5D 20 13 22 00
90 10 0C 01 00 6B 80 10 77 39 00 00 80 00 00 00 00
A0 EF 02 00 5D 00 00 00 00 00 00 00 00 00 00 00 00
B0 2C 73 BF 0A 4B 00 00 00 B3 7B A0 20 00 44 C8 80
D0 06 00 1A 7B A6 40 A9 E4 E7 60 02 08 61 04 A1 44
E0 00 00 8F B2 32 52 8C 28 62 40 89 24 E3 00 29 E2
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF 3B 04 00 40 00 10 0A 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 40 19 E4 B0
60 1F 00 00 00 01 62 1F 00 00 00 00 00 00 00 00 00
70 11 01 32 51 21 40 70 50 00 2A 00 08 17 21 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 30 20 01 40 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 80 0C 25 20 20 00
E0 00 00 00 00 3E 20 48 00 19 17 00 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 B2 0F 06 00
Description VGA Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x00C0
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xDF000000
Address 1 (memory) 0xC0000000
Address 3 (memory) 0xDE000000
Subvendor ID 0x1682
Subsystem ID 0x2178
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 1.0
PCI registers
00 DE 10 C0 00 07 00 10 00 A2 00 00 03 10 00 00 00
10 00 00 00 DF 0C 00 00 C0 00 00 00 00 04 00 00 DE
20 00 00 00 00 00 00 00 00 00 00 00 00 82 16 78 21
30 00 00 00 00 60 00 00 00 00 00 00 00 11 01 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 C0 04 00 00
80 10 28 00 00 01 45 02 00 08 00 01 11 00 00 00 00
90 00 00 00 00 00 00 00 00 0C 08 40 C1 01 04 40 C1
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0503
date 03/26/2008
DMI System Information
manufacturer System manufacturer
product System Product Name
version System Version
serial System Serial Number
UUID 20BC2798-8DFED511-A1B90022-15BB0E44
DMI Baseboard
vendor ASUSTeK Computer INC.
model M2N-MX SE Plus
revision Rev x.xx
serial MF7088G00707492
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
clock speed 2600.0 MHz
FSB speed 200.0 MHz
multiplier 13.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 2048 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Port Connector
designation PS/2 Mouse (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation PS/2 Keyboard (internal)
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (internal)
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (internal)
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (internal)
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (internal)
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (internal)
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (internal)
designation USB7 (external)
port type USB
DMI Port Connector
designation USB8 (internal)
designation USB8 (external)
port type USB
DMI Port Connector
designation LPT Port (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation COM Port (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation Audio Mic In (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (internal)
designation Audio Line In (external)
DMI Port Connector
designation Audio Line Out (internal)
designation Audio Line Out (external)
DMI Port Connector
designation LAN (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation SPDIF_OUT (internal)
DMI Port Connector
designation CDIN (internal)
DMI Port Connector
designation PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation FRONT PNL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation CHA FAN (internal)
DMI Port Connector
designation CPU FAN (internal)
DMI Port Connector
designation SATA1 (internal)
DMI Port Connector
designation SATA2 (internal)
DMI Extension Slot
designation PCIEX16
type A5
populated yes
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] 002215BB0E44
string[1] To Be Filled By O.E.M.
string[2] To Be Filled By O.E.M.
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA NVAPI
API NVIDIA I/O
Graphics I2C
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name NVIDIA GeForce 6800 GS
Revision A1
Memory size 256 MB
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1682)
Model ID 0x00C0 (0x2178)
Performance Level Default
Core clock 350.0 MHz
Memory clock 1100.0 MHz
Performance Level 3D Applications
Core clock 485.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 11.0
ACPI
ACPI Tree
_GPE
_L10
_L03
_L0D
_L05
_L00
_L15
_L11
_L0B
_L09
_PR_
P001
P002
P003
P004
CPU1
CPU2
CPU3
CPU4
_SB_
PR00
AR00
PR11
AR11
PR12
AR12
PR01
AR01
PR02
AR02
PRSA
PRSB
PRSC
PRSD
RSEA
RSEB
RSEC
RSED
RSMB
RSB2
RSMU
RSA1
RSA0
RSB0
RSAC
RSZA
RSCI
RSC9
RSTA
RSIR
RSII
PCI0
_HID
_ADR
_BBN
_UID
_PRT
NPTS
NWAK
SBRG
_ADR
SPTS
SWAK
SMIE
PS1S
PS1E
SXCT
S1CT
S3CT
S4CT
S5CT
PIC_
_HID
_CRS
DMAD
_HID
_CRS
TMR_
_HID
_CRS
RTC0
_HID
_CRS
SPKR
_HID
_CRS
COPR
_HID
_CRS
FDC_
_HID
_FDE
_STA
_DIS
_CRS
_SRS
_PRS
LPTE
_HID
_STA
_DIS
_CRS
_SRS
_PRS
LPPR
EPPR
RMSC
_HID
_UID
CRS_
_CRS
ASOC
_HID
_UID
_STA
MBIF
ASBF
ASB0
ASB1
GGRP
GITM
SITM
OP2V
V2OP
G0T0
G0T1
G0T2
GRP0
GIT0
SIT0
G3T0
G3T1
G3T2
G3T3
G3T4
G3T5
G3T6
G3T7
G3T8
GRP3
GIT3
SIT3
G4T0
GRP4
GIT4
SIT4
G5T0
GRP5
GIT5
SIT5
G6T1
G6T2
G6T3
G6T4
G6T5
G6T6
G6T7
G6T8
G6T9
GRP6
GIT6
SIT6
G8T1
G8T2
GRP8
GIT8
SIT8
G9T0
GRP9
GIT9
SIT9
GAT1
GAT2
GAT3
GAT4
GAT5
GAT6
GAT7
GAT8
GAT9
GATA
GATB
GATC
GATD
GATE
GATF
GRPA
GITA
SITA
GBT0
GRPB
GITB
SITB
GCT0
GRPC
GITC
SITC
GDT1
GDT2
GDT3
GDT4
GDT5
GRPD
GITD
SITD
CORV
V3VV
V5VV
VV12
VPAR
VBUF
VGET
CPUT
MBTP
TBUF
TGET
CPUF
CHAF
FBUF
FGET
QCFN
QBUF
VSIF
RVLT
SVLT
TSIF
RTMP
STMP
FSIF
RFAN
SFAN
QFIF
GCQV
QFST
HPET
_HID
_UID
CRS_
_STA
_CRS
HPTE
NVID
LPDC
S3F8
S2F8
S2E8
S3E8
M300
M330
FDC0
P378
P278
P3BC
G200
G208
RRIO
RDMA
OMSC
_HID
_UID
CRS_
_CRS
PS2K
_HID
_CID
_STA
_CRS
_PRW
_PSW
PS2M
_HID
_CID
_STA
M2R0
M2R1
_CRS
_PRW
_PSW
SIOR
_HID
_UID
CRS_
_CRS
ZZZ1
HWV0
HWV1
HWV2
HWV3
HWV4
HWV5
HWV6
HWV7
HWT1
HWT2
HWT3
HWF1
HWF2
HWF3
HWF4
HWF5
CF08
CF16
FTFR
FHMT
FHM3
FLMT
DTB1
DTB2
ECRE
HIDX
HDAT
FTD1
FTD2
FTD3
ETD1
ETD2
ETD3
FTC1
FTC2
FTC3
EFN1
EFN2
EFN3
VIV0
VIV1
VIV2
VIV3
VIV4
VIV5
VIV6
VIV7
TPI1
TPI2
TPI3
FTC4
EFN4
FTC5
EFN5
DCAT
IKEY
KBFG
MSFG
UR1F
ENFG
ENTR
EXFG
LPTM
UHID
ORF0
ORF1
ORF2
ANF0
ANF2
ANF4
STF0
STF1
SIOS
SIOW
SIOH
IOID
INDX
DATA
LDN_
OP29
ACTR
IOAH
IOAL
IOH2
IOL2
INTR
DMCH
OPC0
OPC1
OPC2
OPC3
OPT0
OPT1
OPT2
OPT3
OPT4
OPF8
OPF9
OPFA
OPFB
CGLD
DSTA
DCNT
CRS1
IRQM
DMAM
IO11
IO12
LEN1
CRS2
IRQE
DMAE
IO21
IO22
LEN2
IO31
IO32
LEN3
DCRS
DSRS
GPIO
GP10
GP11
GP12
GP13
GO14
GO15
GO16
GO17
GP20
GP21
GP22
GP23
GO24
GO25
GO26
GO27
GP30
GP31
GP32
GP33
GO34
GO35
GO36
GO37
GP40
GP41
GP42
GP43
GO44
GO45
GO46
GO47
UAR1
_UID
_HID
_STA
_DIS
_CRS
_SRS
_PRS
CMPR
_PRW
PIMC
_S3D
_S1D
NATA
NVRB
_HID
_STA
_CRS
PCIE
_HID
_UID
CRS_
_CRS
USB0
_ADR
_S1D
_S3D
_PRW
USB2
_ADR
_S1D
_S3D
_PRW
IDE0
_ADR
PTS0
SID0
SID1
SID2
SID3
SID4
SID5
IRQM
IR0M
REGF
_REG
A090
ID20
IDTS
IDTP
ID22
UMSS
UMSP
TIM0
TMD0
PIO0
DMA0
PIO1
DMA1
CHNF
CFG2
SSPT
SMPT
PSPT
PMPT
SSAS
SMAS
PSAS
PMAS
SDDR
SDDA
PDDR
PDDA
SSUT
SSUE
SMUT
SMUE
PSUT
PSUE
PMUT
PMUE
GMPT
GMUE
GMUT
GSPT
GSUE
GSUT
CHN0
_ADR
_GTM
_STM
DRV0
_ADR
_GTF
DRV1
_ADR
_GTF
DRMP
GTM_
STM_
AT01
AT02
AT03
AT04
ATA0
ATA1
ATA2
ATA3
ATAB
CMDC
GTFB
GTF_
RATA
P0P1
_ADR
_PRW
_PRT
HDAC
_ADR
_PRW
SGPU
_ADR
P0P2
_ADR
_PRW
_PRT
BR11
_ADR
_PRW
_PRT
BR12
_ADR
_PRT
NMAC
_ADR
_PRW
NSMB
_ADR
_PRW
ATA0
_ADR
PRI0
_ADR
SPTM
_GTM
_STM
MAST
_ADR
_GTF
SEC0
_ADR
SSTM
_GTM
_STM
MAST
_ADR
_GTF
DRMP
CRS_
MIN5
MAX5
LEN5
MIN6
MAX6
LEN6
_CRS
BN00
SMIP
LCTM
LCNM
RMEM
_HID
_UID
CRS_
_CRS
PWRB
_HID
_UID
_STA
BUFA
ICRS
LSTA
LPRS
LCRS
LCRO
LSRS
LSRO
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNED
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LUB0
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LUB2
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LMAC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LAZA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LACI
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LMC9
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSMB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LPMU
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSA0
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSA1
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LATA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
XCPD
XNPT
XCAP
XDCP
XDCT
XDST
XLCP
XLCT
XLST
XSCP
XSCT
XSST
XRCT
MUTE
RBPE
RWPE
RDPE
WBPE
WWPE
WDPE
RWDP
RPME
_SI_
_TZ_
_REV
_OS_
_OSI
_GL_
DP80
DP90
SPIO
IOPB
IOPL
IOEB
IOEL
IOGB
IOGL
IODB
IODL
IO1B
IO1L
IO3B
IO3L
SSMI
SSEP
SSEN
APIC
SHPB
SHPL
PMBS
PMLN
SCBS
SCLN
ACBS
ACLN
MTAB
MTAL
IGPB
IGLN
ACA4
SCIO
SCTL
EXTS
SGPS
SGPM
SGPL
SNAS
SNAM
SNAL
T1OF
T2OF
T3OF
CQST
PCIB
PCIL
WKTP
BIOS
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
MG1B
MG1L
MG2B
MG2L
DMAX
HPTA
CPB0
CPB1
CPB2
CPB3
ASSB
AOTB
AAXB
SMIF
DTSE
DTS1
DTS2
MPEN
RRIO
RDMA
PICM
_PIC
OSVR
OSFL
MCTH
PRWP
GPRW
WAKP
DEB0
DBG8
DEB1
DBG9
SCPP
APA4
RAMW
PAR0
PAR1
PAR2
TOP1
UMAS
IOB2
SMIC
SMIS
ISMI
GNVS
SNVS
LVVB
LNVB
FZTF
PIRA
PIRB
PIRC
PIRD
PREA
PREB
PREC
PRED
PIRM
PIU2
PMUD
SIID
PIID
PIU0
PIU1
PILN
PAZA
PAUI
PIMO
PR0E
NPTS
NWAK
CPUQ
CPVL
CPVH
CPVC
WOTB
WSSB
WAXB
_PTS
_WAK
GPEB
RTCS
_S0_
_S1_
_S3_
_S4_
_S5_
PTS_
WAK_
