- Dec 17, 2004
- Calgary, Alberta
Some TIM probably dried inside the chip and made IHS contact worse.
Super Nade said:madhatR, did you burn your CPU in? Gpl Racer, you can increase the VCore as long as the temprature is under control ( say < 52C).
tranceaddict said:No offence, but you guys have to learn how to construct proper polls. You have to have categories which are mutually exclusive. In other words, the categories need to be completely independent of one another, and not overlap. In this particular poll, if someone manages an overclock of 2.6GHz, which category do they choose? Moreover, the category margins are too wide to give a statistically significant outcome.
OnDborder said:Ok..I like that stresscpu program.
What settings to reach 1.5? 1.325x113? Or just 1.5xauto? Or 1.225x123?
Super Nade said:Guys, are you taking the RAM out of the equation before running your CPU stressers? Make sure your RAM is at a guarenteed stable setting. Its a nightmare to debug multiple unstable components. Also make sure your LDT multiplier is chosen appropriately. HT Bus freq < 1000 MHz or else you will have problems. Also, you may need to bump up chipset voltages. Just a few things to keep in mind. Somestimes its not always the CPU.
Super Nade said:No offense, but you must learn how to read the whole thread before commenting. There is a clarification posted right below.
There are a limited number of options available in a poll (limitation of vbulliten). If the objective was to perform a statistical analysis, a poll would be a wrong way to go about it. Instead, I'd opt for direct data collection. If you read the first post, it is apparent why the margins are so wide. One has to accomodate Dual and Single core Opterons. If a statistical analysis needs to be done, I will refer to the quick reference, scrolling table for this purpose.
If you have any data to contribute, please do so. I'm not sure what your point is beyond the asthetic qualities of the poll?
