Someone is looking to supply me with this PSU. I think they called it a Superchannel.
Features
80PLUS(R) certified and NVIDIA SLI ready for whole series. Fully modular
cabling design enables you to connect only the cables you need.
Component: Use high reliability of components:
To maximize heat release, Powerex use golden heat sink and select stable
quality of Buck Capacitors made in Japan and the other semi-conductor
components from world-class main manufacturers at higher cost.
Reliability: To provide high efficient and reliable power supply by
using reliable quality of components and well circuit layout design.
This is to make sure a stable power supply environment for your system
without system break down caused by unstable power supply.
Fully modular detachable cabling design enables you to connect only the
cables you need.
80PLUS(R) certified and NVIDIA SLI ready for whole series to ensure
users a system environment without concerning of unstable power output
voltage and save the electric expense.
Voltage INPUT:110-240V
Output Voltage
Load
MIN
Range
MAX
Regulation
Ripple
P-P Max.
Ripple & Noise
P-P Max.
1. +5V
2.0A
30.0A
+-5%
70mV
100mV
2. +12V1
1.0A
18.0A
+-5%
120mV
200mV
3. +12V2
1.0A
18.0A
+-5%
120mV
200mV
4. +12V3
1.0A
30.0A
+-5%
120mV
200mV
5. +12V4
1.0A
30.0A
+-5%
120mV
200mV
6. -12V
0.0A
0.8A
+-10%
150mV
200mV
7. +3.3V
0.5A
30.0A
+-5%
70mV
100mV
8. +5Vsb
0.0A
3A
+-5%
70mV
100mV
Specifications
Max. Dc Output 850 W
Input Voltage 110-240VAC+-10%
PFC Active PFC (PF>0.95 at full load)
Efficiency
The power supply efficiency shall not be less than 80% at the maximum
load of sec. 2.2 and 115 / 230Vac input voltage.
MTBF 100,000 hours at 25℃, full load
Operating temperature 0 ~ 40 degreesC
Protection
Over current protection, Over power protection, Over voltage protection,
Short circuit, No load operation, Under voltage protection.
135mm Fan Speed Controlling for Better Cooling &Less Noise
Cooling System Single 135mm sleeve fan
Noise Level 31.7dB (MAX)
Dimension 150x86x158mm
