HP Z400/Xeon Workstation to Gaming Desktop build thread...
Hey guys! Notice the builds here are from the Z400 v2 which feature 6 ram slots. I am having the z400 v1 which only has 4 ram slots and a memory max cap at 16GB. I have read the offical manual to see what CPU and ram I could max out. Any others here own a Z400 v1 could assist on this questions?
1) Could I I use the W3690 on my mobo. Understand offically z400 v1 does not support 6 cores CPU and v2 supports W3680 only
2) Currently running 12GB triple channel on the z400 v1. If I max it out at 16GB it will only run at dual channel. Could I run 3x8GB for a 24GB triple channel config?
Cooler Master Hyper 412S heatsink clamp bracket problem solved.
Dremel cutting with small steps avoid heat.
