- Apr 20, 2004
- JAX, Mississauna
RMA = Return Merchandise Authorization = Get okay to send back for replacement of bad unit.
Everything else works fine. BTW, what RMA stands for ?
Thanks guys for clarificationRMA - Return Materials Authorization
RGone you beat me to it....
That's exactly what I was going to say...Since this only happens at above stock frequencies you might have a problem getting an RMA. Normally, vendors and manufacturers won't acknowledge problems that occur only when overclocking, even when they make something to be overclocked.
Hehe, ok sirGet it ramped up, hell that chip is made for overclocking, just go off the socket temp and you will fine
this is common to msi boards, i returned two in two days showing core temps over 200c at idle.
changed to another brand and all is happy. here is a screenshot.
And is why, I no longer recommend them at all. Nor Biostar. I travel the net greatly looking for answers and those two companies are nowdays just n0t seeming to get it done by my own personal look-sees. OMMV.
I have had to give up on gigabyte my first two boards and cpu's roasted because of gigabyte vrms.
my 995 rides in a biostar ta790gxa3+ and i really like the machine, it's sad to hear biostar has not kept up.
man... how i change vcore at this motherboard because i dont have this option in bios...i have exactly same motherbord as you.only voltage i have is set ffd-cpu voltage.wich more than 1.35v cant be set and it`s at max.my cpu v-core is 1.29v ( @ 3,92ghz. my cpu sempron 145
