FRONTPAGE HyperX Announces Three High-Speed Additions to the Predator DDR4 Line-up
HyperX has just announced three additional ram kits for the Predator DDR4 line. These new ram kits will be available as 8Gb modules and sold in pairs (2x8Gb). The rated speeds are an ultra-fast 5000Mhz with a CAS latency of 19, 5133Mhz with a CL of 20, and 5300Mhz CL20. Starting price for these new SKUs start at $870 for the 5000Mhz kit. For additional information please read the following press release from HyperX.
Click here to view the article.
I guess it's more to show that they can provide DDR4-5333 than to make money from sales. These kits will be barely available but you probably have a much higher chance to buy them than anything from brands like G.Skill which are flooding us with press releases of top RAM which isn't available in stores at all. Check top motherboards QVL and you will see some brands with DDR4-5000+. Almost nothing from these kits is available in stores or costs $700+. Most of these kits are EOL at the test stage.
Btw. you can expect about the same IC in these kits as in DDR4-4600. Recently, I slightly passed DDR4-6400 on one of them, where the maximum stability in dual-channel was around 5200-5400 (probably some problems with IMC/motherboard at reasonable voltages). I will back to this kit when I finish some other tests. Anyway, one thing is to have so fast memory kit, the other thing is to have a strong IMC and a good motherboard to make it work at least at XMP settings.
Personally, I wouldn't buy a 16GB memory kit for a new gaming PC but that's other thing.
I really worry about compatibility of these kits. I don't doubt they will work at their claimed speed in some system with some CPU, but it will be far from all systems with all CPUs. Might be another manufacturer, but I think in the past they had to list tested mobos for extreme speed kits. Or have things moved on and extreme speed kits work more often now? Let's define extreme as something sold as 5000+.
There are multiple B550, X570, Z490, and Z590 motherboards that support DDR4-5200+. However, these new kits are listed up to DDR4-5333 almost only on Z590 motherboards. Count maybe 3x ASUS ROG, 3x top MSI, 2x top ASRock, 3-4 top Gigabyte.
Even though B550 should handle up to DDR4-5600 and some motherboards have memory kits up to this speed on the QVL, then barely any new Hynix DJR based kit (count these HyperX too) is listed on AMD. There are "older" DJR up to about DDR4-5000. This is also because most Ryzen 5000 CPUs will hit a wall at DDR4-5000 or even lower clock. Only Ryzen 4000 will go up to DDR4-5300+. Also, B550 motherboards support higher memory frequencies than X570.
In short, you need Z590 motherboard and 11th gen CPU to run RAM at DDR4-5000+ without issues. It will still require high voltages but will probably work at XMP settings.
In my tests it was about like:
B550 (ASRock, ASUS) - DDR4-5100 stable with Ryzen 5900X, DDR4-5000 stable with Ryzen 5600X/5800X
B550 (ASRock, ASUS) - DDR4-5300+ stable with Ryzen 4650G
X570 (ASRock, ASUS, MSI) - DDR4-5000 stable with Ryzen 5900X, DDR4-4866 with Ryzen 5600X/5800X
X570 (ASUS, MSI) - DDR4-5200 stable with Ryzen 4650G
Z490 (ASRock, ASUS, MSI) - DDR4-5000 stable with i9-10900K
Z590 (ASRock, MSI) - DDR4-5200 stable with i7-11700K
Results with Micron B and Hynix D. Samsung can't make much above DDR4-5000. There is also the "luck" factor as not every CPU is the same.
Some Z590 motherboards have support up to DDR4-5600+ and some memory kits at this speed are on the QVL. I assume we won't see them in stores. Anyway, you can set DDR4-5600 on something like MSI Z590 Unify ITX/ATX/-X, Gigabyte Z590 Tachyon, ASUS Apex or ASRock OC Formula. It will still require good IMC and very high voltages (at least compared to regular values).
Here is valid at DDR4-6400 with HyperX Predator RGB DDR4-4600 made a couple of days ago on MSI Z590I Unify - https://valid.x86.fr/quwxlt
Not stable but it's full air/stock cooling.
I love Kingston hyperx RAM. Recently I bought one from BuyKingston and it's doing the job pretty well. Anyway, I would also like to buy one of these when they are available.
Welcome to the Forums Jack!
Good luck finding a pair of these. Many manufacturers release these very high-speed kits but rarely are they seen in the wild. That's not to say they are impossible to get, but very difficult. If you find a pair for sale, do not hesitate to pick them up. They won't be for sale long.
