treepop said:but is it worth the 20 bones extra?
Mizzery said:The real question is wether or not that 2 degrees is worth $20 to you.
Maxvla said:slk800 plus fan is at most 60 bucks.
difference between p4 2.4b and 3.06 is like 400 dollars.
i don't see how anyone is spending more money doing the cooling way???
You and others might want to consider the SLK-900U for an option to the SLK-800 or Alpha 8942.Maxvla said:for me the differences between the stock intel cooler and the slk800 were about 9 degrees under load when i had my 1.6a @ 2500mhz.
i will be purchasing another slk800 for the p4 system as the other one was intended for my new amd system.
most definately worth it.
filip04 said:: you cna't put a 80mm fan on a slk7, can you??
