- May 28, 2004
Ok I have been reading up on HTPC builds and stuff. I can pretty much fill in the blanks on most of the hardware, but there are some things I just have no idea which path to take, or even where to start.
Here is what I will be using my HTPC for.
1) Gaming - Mostly MMO's, and some single player games
2) DVR - so I need plenty of HD space probably
3) I want to hook up a set of Z-5500's to save some cost on a separate receiver.
4) Will be using my 19" LCD, along with a 42-46" LCD/Plasma 1080p TV. Will they work? I won't be using them at the same time, it'll be either monitor while gaming, or TV while watching... well TV.
5) Not even the slightest clue on which TV Tuner card to go with. I wanted to get an ATI AIW, but I see ATI isn't releasing there upper tier cards with that feature anymore.
6) Listening to some music, but not a lot.
7) What software would I need to buy to do everything I want? I am probably going with Vista Ultimate 64bit.
8) Will be running a Playstation 3, can I use that as a media center and just use my gaming computer to store the movies and stuff? Would I hook the PS3 up to the PC?
That pretty much sums it all up.
My follow up question is this...
Should I bother mixing a gaming PC, and an HTPC? Should I just avoid the HTPC all together, and get a surround sound setup w/receiver? I am not sure if I am just asking for more problems mixing the two? Maybe, should I build an el' cheapo HTPC and a really good gaming rig?
