You should be able to find a good 512mb videocard for like 180 bucks. Down grade the card and you can go to the 8400 instead of the 8500 to save a few more bucks.
Yea it should display a higher res if you set it but it would evetually burn out the monitor.+1 for the 8400, is the same as 8500 except that is clocked to 3.0 instead of 3.1, if you are overclocking and you probably will then you can save with the 8400.
Also the monitor resolution thing goes like this, his monitor max resolution is 1680x1050 but it won't scale well, how do I know this? I have a 17" CRT same as him, only that my normal res is 1152x864 (although I always use 1024) , I can manually change it to 1680 and it will work but it doesn't look good and most programs won't even display that option.
if you are going to be gaming a 1024 then just get a used 8800GT for $90 and save your money for a better monitor and video card down the line. At 4870 at that resolution is not just overkill but a waste of money. If it takes you a year to get the monitor even a 4870 will be at least a generation old, and at the ~$100-~$150 price point. So you will have spend double the money with essentially no benefit. in general future proofing is a bad idea, especially when it costs you. But to satisfy your needs and not what you may or may not need in 6 months to a year.
We already went over everythign you said. Hes buying a good monitor down the line to play at 1680x1050. The videocard isnt over kill, you missed the recent posts. Hes upgrading his monitor when he has money and buy the card now so he doesnt have to change it with his monitor. If he bout an 8800gt it would be a waste because hes gonna buy a new monitor.
RaV3N thanks for your contribution again. I think ou_phidelt didn't misread or skip a few lines. What he is saying is that when I buy a monitor in say half a year I will not benefit from what I purchase now, by that time the HD4870 will be "old" and then I have spend like 100 bucks for nothing because my monitor could not handle it. He is saying like buy a cheaper videocard now, so that, as you buy a new monitor, you can buy a new videocard and leave the rest of your system the same.
But I was just wondering, this system seems like higggggggh. If I want to play the new games, CoD5, CoD4, etc. on like 125 - 250 fps, do I really need this to run it or will a cheaper motherboard and cheaper processor etc. do the work? if so, what processor, motherboard and videocard etc. will do that work?
To save some cash, get a Radeon 4850 card and the Intel 8400 CPU.
Eg. of the card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
Will still drive your new bigger monitor plenty fine for most games.
