- Dec 21, 2004
- Atlanta, GA
Hello,
I posted a thread asking advice about my new system and new water cooling loop here:
http://www.overclockers.com/forums/showthread.php?t=656671
For those too lazy to click here is what I ordered:
I just had a few last minute questions before I put everything together tomorrow and leak test:
#1 I will be top mounting my radiator inside my HAF 932. I've come to the conclusion that the optimal configuration is to have the radiator mounted just below the top of the case with my three fans pulling air downward and being swept out by the exhaust fan in the rear of the case. Is this correct?
#2 I wanted to try and fit both my pump and reservoir inside my drive bay area to keep as much of the interior as clean looking as possible. I will only be using one 5.25" drive bay for my burner. I'd imagine it may be a tight fit but if it all manages to fit then is there any downside to having minimal tubing between the reservoir and pump so long as the reservoir is above the pump? I'm talking like just enough to connect the two without the occurrence of kinks since space will be limited. Or would it be better to have the pump at the floor of my case with a longer tubing length between the pump and reservoir, or does it simply not matter?
#3 When preparing my radiator and water block I intend just to use hot distilled water. Is this okay? If so, what would be the best and easiest way to heat my gallon jugs? For the radiator I'll just flush it repeatedly until clear water comes out. For my EK Supreme HF what would be the best way to prepare it? Will I need any rubbing alcohol or anything else before starting? I'll have latex gloves and a full kitchen and bathroom available as well as new ArctiClean 1 & 2 bottles (2 is a thermal surface purifier).
Thanks in advance!
Code:
[B][U]FrozenCPU[/U][/B]
$71.95 - [URL="http://www.frozencpu.com/products/8525/ex-blc-569/EK_Supreme_HF_Universal_CPU_Liquid_Cooling_Block_-_Rev_2_-_Acetal_Sockets_775_1156_1366_939_940_754_AM2_AM2_AM3.html"]EK Supreme HF Rev 2 Acetal[/URL]
[B][U]Petra's Tech Shop[/U][/B]
$65.95 - [URL="http://www.petrastechshop.com/lad5smcin12v.html"]Laing D5 Basic/Swiftech MCP655-B Inline 12V DC Pump[/URL]
$49.95 - [URL="http://www.petrastechshop.com/swmcqposerab1.html"]Swiftech MCR320-QP Quiet Power 3X120mm - Matte Black[/URL]
$22.95 - [URL="http://www.petrastechshop.com/swmcmirere.html"]Swiftech MCRES-MICRO Rev2 Reservoir[/URL]
$3.00 - [URL="http://www.petrastechshop.com/heclnyhoclsi3.html"]Herbie Clip® Nylon Hose Clamp Size H - Black[/URL]
[B][U]Jab-tech[/U][/B]
$18.00 - [URL="http://www.jab-tech.com/PrimoFlex-Pro-LRT-Black-Tubing-1-2in.-ID-X-3-4in.-OD-pr-4190.html"]PrimoFlex Pro LRT Black Tubing - 1/2in. ID X 3/4in. OD[/URL] (10 feet)
$3.95 - [URL="http://www.jab-tech.com/Antimicrobial-Silver-Strip-pr-4530.html"]Antimicrobial Silver Strip[/URL] (8" Silver Strip)
$11.00 - [URL="http://www.jab-tech.com/Bitspower-G1-4-Matt-Black-1-2-Fitting-BP-MBWP-C01-pr-4516.html"]Bitspower G1/4" Matt Black 1/2" Fitting[/URL] (4 of them)
$9.90 - [URL="http://www.jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SH-12-High-Speed-pr-3771.html"]YATE LOON 120mm Case Fan - D12SH-12 - High Speed[/URL] (3 of them)
Thanks in advance!
