- Sep 6, 2003
With my laptop my framerates can never get that high, it seems like im running between 20 and 50 depending on the scenario, 50 I can live with but that seems to be my high, 20 is my low, that is with all settings turned on high, simple reflections no aa or af, resolution of 1680x1050
so I tried turning down the settings, I put them all at low, and 800x600 res and that got me maybe aother 7-10 fps.
this seems odd to me as my old comp played cs:s significantly better. This comp is Dell 9300, 1.2 gigs of ram, 6800go at 757/357, 1.6 ghz pentium-m cpu.
My old computer was a AMD xp-m 2500 @ 2.35, 768 megs of ram, 9800 pro at 425/385, on this comp I got always at least 40fps or so
the only place i can figure out where my laptop is worse than my old desktop is cpu, but the dothan cant be THAT much worse than the amd 2500 can it, am I really that cpu limited?
Every other game works quite a bit better than on my old comp, except CS:S, farcry works WAY better, Doom 3 works WAY better, but CS:S works quite a bit worse, why?
BTW, my computer is hardly running any processes in the background, and has no spyware/adware/viruses that I know of?
Im currently using the lastest dell drivers which are not that new, I know, will updating my graphics drivers help that much? should I upgrade to the 80 series of drivers?
