- May 15, 2015
750W PSU
GTX 960 4GB GIGABYTE
Intel Core i7 920 from 2.66GHz to 3.8 GHz stable
8GB of ram
2 TB HDD
Motherboard - Gigabyte GA-EX58-UD3R v1.6
Windows 7 Ultimate 64bit
So, I played with this system before, except GTX 960(2 days old) and overclocked CPU. I had stock CPU and a GTX 560 Ti 1 GB. I had random lag spikes and I though that that is the GPU fault, but.. I installed 960 and overclocked CPU to 3.8 GHz(it runs fine, around 50C while gaming). For example, GTA 5 - everything at highest set. - 60+ FPS with drops per 20 sec or more. That is not the point. The point is that I get these spikes in almost every game. I tried to unpark CPU cores and I think it helped with Battlefield 3, so now I can play at 1080p Ultra 80+fps, but... there is still some spikes. I mean, not like LAG, because it stays at 80 and drops to 70 for hmm.. like 0.4 sec and comes back to 80. You understand me Windows are fresh installed, system clear from dust, newest directX, all in all, the PC works great, just.. these lag spikes.. damn I hate them. They are not so much visible, but I play concentrated and I can see them. I don't know guys, maybe the CPU is old, but still.. 2.66 GHz to 3.8 Ghz should improve the performance. I mean, the overclock improved it, more fps etc., but the lag spikes seems to be the same. No temperature issues, nothing, no virus, defragmentation done. It seems that it should be fine, but there is still these DAMN lag.. any ideas? and.. btw, on BIOS settings all power saving features are disabled.
UPDATE... SEE POST 30:http://www.overclockers.com/forums/...lag-spikes-)?p=7825281&viewfull=1#post7825281
8GB of ram
2 TB HDD
