- Sep 15, 2001
Well to keep a long story short I tried water cooling about 3 years ago, but I bought cheap and got crappy performance. Besides that I was only cooling a AXP anyways so air worked just fine. Now I have a Prescott that has similar wattage to lets say.... the sun, and as I type it's fusing the silicon to iron. or about 64c. I've done some research and came across a few parts that I feel will fit the build and offer the performance I need now and to expand into later on down the line.
Now the look I'm going for is a multi 120mm setup mounted to the top of my box and have only the CPU WC for the time being. This Picture is the look I'm going for.
Now here's what I'm looking into:
Pump: MCP350, from what I hear this thing is a watercoolers dream machine, small, quiet, reliable and has pressure and flow to that of a 1048. Is this all true?
Water Block: Apogee, I read that it has similar performance to that of the storm and cheaper, however it can crack at the base due to excessive force pushing on the lines.
Tubing:Tygon 7/16in, best of both world between 3/8 and 1/2 being it can corner with ease as well as carry a good 10lpm without skipping a beat, or so I hear.
Radiator: Here's the million dollar question... Is the Black Ice Pro III that much better then the II? Size isn't a factor being the radiator is going to be on top, also price isn't a factor unless the gain is minimal. I'm pretty sure that a II would be more then enough for the CPU (125w worth) alone however I'm looking into something that will take a 6800 or 7800 later down the line as well as maybe a chipset or so.
TIA
TIA
