- Feb 15, 2006
Hello I need a video capture solution for recording PC Mirrors Edge Gameplay. I have a gtx 260 and a 8600gt. If I use fraps it lags so I am hoping there is a way to capture my gameplay at full resoulution and speed.
Can I use a 8600gt which wouldnt be used for gameplay to capture video. I have never tried to capture any video and I dont have a need to capture TV or watch TV etc.
So far I have it in my head I may even need to use an svideo jumper out of my gtx 260 and into the 8600gt if it is capable of recording. Also If it is capable I hope there is a way wihtout using a jumper as it would be cleaner.
I am fully willing to buy a video capture card if that will do the job any reccomendations? Will that have to be done via s-video cable or will a video capture card record directly a type of "record what is on screen" deal.
Also I What exactly is a wdm driver and I have access to a 7800GT if that will do it also. Will a wdm driver work on my 8600gt? 7800GT?
Also Is it a better or ideal way to record having a second PC hooked up if you have to use a svideo cable etc?
I am just looking for the best way to record full game footage from my PC Hopefully full size and fps then I will edit it down later. I will settle for lower resolution etc. I just have to be able to play my game full speed and resolution I game at 1680 x1050.
Other note on the PC version I have The Arland World Record time trial with 38:59 and I am 4th on heat and 9th on chase.
