- Nov 11, 2010
Been hearing some odd sounds lately from the Intel side of me case and, when I got home from work yesterday afternoon and powered up then logged in, I started getting the Corsair Link warnings that the computer was way too hot. (I set it conservatively to 83°C)
I powered it off, waited 10 minutes, powered it back on and it booted up and I logged in. About a minute later I got the same hi-temp alarm so I turned it back off.
Opened the side panel, checked to make sure everything was plugged in and jiggled the tubes a bit, then closed everything back up, powered it up and it ran fine the rest of the night with temps never exceeding 39°, even at 4.2GHz (i7 4770K) but the pump is making a clicking sound.
I think the bearing in the AIO is going out.
I figure if the pump is what's going bad I've gotten good use from it (it's been in 4 cases and 6 builds) so I may just upgrade that side to a new system.
Anyone see the same kind of symptoms with the pump section making a "clicking" sound before?
