Just bought some news bits and boy was it overdue. Unfortunately something is not working
I upgraded from:
Q6600 2.4GHz
Asus P5N-E SLI
8GB DDR2-800 (4x 2GB)
MSI 750 ti
750w no name PSU
60 + 120 SSD
1TB HDD
To this:
i5 4460
Gigabyte H81M-DS2
8GB DDR3-1333 (2x 4GB)
MSI 750 ti
Corsair CXM430W
60 + 120 SSD
1TB HDD
Firstly, it never restarts. It just shuts down and keeps the power on with a black screen, no start up beep, nothing.
Secondly it always crashes with the 750 ti at boot up, I just see a black screen, the one beep and then a mouse cursor at what seems like 640x480 res size and sometimes it's tail chopped in half.
I've bread boarded the setup to quickly swap things and first thing tested was the PSU. This works with the old setup as well, no crashes, booting into windows fine and throwing a stress test at the q6600. I then tested the 750 ti on the old setup as well and that worked fine, opened up a game and that was ok. Not even a hint of trouble there.
On bread boarding the new setup it beeps like mad with no ram as expected. I tried the no gpu of course but the CPU and the motherboard (I think?) have on board graphics so I don't know if it should beep or not without a gpu. I've swapped the two sticks around and used one at a time in either slot and the same things happen. Booting into windows is ok, but only on a true cold boot of switch off, unplug, plug in and switch on. Reboots never work, not even one time to give me hope. The reboot thing is so bad that installing windows does not work because something happens with the boot sector (error 0xc0000034 on starting to load the installation after first reboot).
Do I have a broken motherboard? Any ideas?
I upgraded from:
Q6600 2.4GHz
Asus P5N-E SLI
MSI 750 ti
750w no name PSU
60 + 120 SSD
1TB HDD
To this:
i5 4460
Gigabyte H81M-DS2
MSI 750 ti
Corsair CXM430W
60 + 120 SSD
1TB HDD
