I have an i5 3570k and z77 extreme 4. I just put it together and got it up and running other day. Everything is 100% stock. So I start looking into overclocking the i5 and run a few benchmarks and stress tests to get a baseline. Intel Burn Test on 100% max is peaking my i5 at 105c. It should be like 80c or so? Or is that normal? Under no load it is between 35-40c.
So I thought maybe it was not seated correctly. I took off the supplied Intel cooler, reapplied the arctic silver 5, as they rec. on their website, and reseated the heat sink. Run IBT again and same result, 105c.
Obviously it could be the heat sink, but i've never seen one (other non i5's) run that hot even with stock.
Any ideas? Could it be a bad i5?
