- Dec 4, 2008
Recently traded i5 661 with "dejo" for this i5 650
My thoughts? I didn't notice any difference of overclockabilty between the two cpus.
Compared to i3s? Not much either.
Believed or not, 4.50Ghz is stable with AUTO setting except for the ram's timing value and its votage was set at 1.66v
All power savings were turned OFF
Idle: 1.456 = 83 watts
Load with Prime95 sFFTs = 1.488 = 163 watts
Though, vcore could and should be lowered a little bit manually but I didn't since I wanted to see how far with an AUTOMATIC mode could take. Very easy indeed....and did I mentioned 4.50Ghz?
25*180 bclk
Using its IGP chipset H55 (Gigabyte H55M UD2H)
Kingston HyperX 4GB 2000Mhz KHX2000C9AD3T1K2-4GX
Venomous X with 2 (12cm) Artic Cooling PWM low noise fans for PUSH/PULL configuration
Hitachi 1TB w/32MB cache
Antec GREEN 380W continous power supply
4500MHz_MostOnAUTOmode_LOAD_1.488_2hr07min
http://i48.tinypic.com/amsdhz.jpg
4500MHz_MostOnAUTOmode_Idle_1.456_2hr11min_HALT
http://i45.tinypic.com/317a00g.jpg
4500MHz_798-20_wPrime32M_10.578s
http://i47.tinypic.com/25teoae.jpg
Later added a 7300GT GPU....with very much all settings were manually adjusted in bios for higher speed benching.
4700MHz_9109-24_SPD10_wPrime1024M_323.015s
http://i50.tinypic.com/8widl2.jpg
4875MHz_9109-24_SPD10_wPrime32M_9.765s
http://i47.tinypic.com/2q8dfsi.jpg
4975MHz_9109-24_SPD10_SuperPI_32M_8m31.140s_All
http://i50.tinypic.com/f251n5.jpg
5000MHz_9109-24_SPD10_piFAST_18.33s
http://i50.tinypic.com/2d98x1c.jpg
5000MHz_9109-24_SPD10_SuperPI_8.469s_All
http://i48.tinypic.com/rbe4p5.jpg
http://valid.canardpc.com/show_oc.php?id=1256987
i5-650_BENCH_SSM
http://i47.tinypic.com/5b5o38.jpg
25*180 bclk
i5-650_BENCH_SSM
