Hi everyone, I'm new to the forum.
Two days ago I delidded my 6600 (non-K) hoping to get better temperatures.
My CPU is overclocked to 4.4GHz at 1.33V using the BCLK OC method (on a Z170 Gaming M3 from MSI), and it's cooled by a 1 year and 3 months old LEPA Aquachanger 240 AIO (with Corsair's SP120 fans on it).
I had this CPU running at a maximum of 85°C, which seemed to be a bit high for a liquid cooler, so I wanted to delid my CPU.
I used the 3D printed tool method with the vice, and it worked fine.
I used CLU between die and IHS, (and I don't think the application of it isn't right, since I removed it and put it back a few times trying to fix my problems, and there was a trace of it under the IHS, indicating that it touched it), and MasterGel Maker Nano between IHS and WB.
I also scraped off all the silicone between PCB and IHS (there are still some traces left, but they aren't making any extra thickness).
And now all my problems start.
I boot up the PC, fire up HWiNFO and Prime95 (26.6, without AVX instructions), and I see temperatures of 95-105(!!)°C.
I thought I ****ed up something, so I went on and replaced CLU.
Still the same.
At this point I started thinking that my CLU was somewhat fake or something, so I tried putting some MasterGel instead of it.
While doing this, I noticed that, 25 mins after I shut down the PC, my rad was cold, tubings were cold, wb was cold, but the part of the wb that makes contact with the CPU was still somehow hot.
I thought something was wrong with the AIO, so I went on and replaced it with the stock cooler I still had in the box.
Reboot the PC, and I see 40°C idle and up to 100 under Prime95 (we're still talking 4.4GHz 1.33V, and it's still 5°C less than the AIO), so I left it like that, thinking everything was ok.
Later that day I decide to perform a CMOS reset. Then I fire up Prime95 again and I see temps up to 91°C, at now stock frequencies and voltage, even though tests say that a non delidded 6600 should stay between 80 and 85°C.
I don't have any idea anymore, what could be causing this? Did I just break the laws of physics?
Thanks in advance.
Still the same.
Thanks in advance.
