- Jul 16, 2013
Would this be sufficient if no OC is done to the i7-4770?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
30 dB though.. isn't that loud? I'm getting a thermaltake commander case.
Are there any cheaper coolers that are quiet? Do cheap fan ones work like this or are they bad?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
