top and bottom intake, only the 1 in the back exhaust.
I think it is the best configuration for taking GPU and CPU cool with low fan speed. of course, inside temp and VRM suffer on workload but not so much
Anyway, I am not happy at all with the DDC pump noise, I think I want to go back to d5 pump.
I already own 1 Phanteks evolv x case, and an alpha cool d5 pump and reservoir,
I like the Phanteks case, but it can fit only 1 420 60mm radiators at best (if I use the Phanteks I want to go for a dual system pc, so the up space is busy).
My question is if I do the change, do you think I lose a lot of quiet ant temps from 2 x 360 radiator (1 60mm + 1 45mm) to 1 420 60mm with 3 intake fans on the radiator and 1 exhaust fan?
I like to chance to go with 1 420 alpha cool Monsta (90mm I think) with push-pull, but I think it doesn't fit inside the Phanteks without modding the case, and not sure if is worthy.
Have you adjusted its speed?I cant del with this ek pump anymore... to high pich noise... Any advise about a very good silent ddc pump?
