First time poster here.
I just built my first water cooled setup. It's based around the new i7-4790k. I'm using EKWB Supremacy waterblock in CPU and EKWB on GPU also. D5 pump on highest speed.
My worry is that I'm getting about 80 degrees (C) temperature on the cores when running prime95. The water temperature is about 32 degrees. Is this normal or do I have bad contact between CPU and waterblock?
