Ive done some research on this, and i know if i did 2 loops for what i want i would be fine. However, because of space issues i dont have room for another loop... here it goes...
I have a TC 120.3, apogee xt on my i7 920, and a MCP655 pump.
Im very happy with my temps, but my damn 4890's sound like they are going to take off!
I have 2 questions...
1) if i added another TC 120.3 and both gpu wb's to my loop (one big loop) would i be looking at high cpu temps? Wattage-wise it should be enough radiator assuming each radiator can handle 5-600 watts each at ~15* delta (on the high side) but im wondering if adding them to the same loop does that change things as far as delta temps are concerned? The graphs didnt really talk about multiple rads in a single loop so i wasnt sure how that worked...
2) will the single mcp655 be able to push the whole loop efficiently? Looking at peoples setups similar to mine, they run multiple pumps but i have seen mostly mcp355's used, so wasnt sure if the 655 would do the trick?
