Hello,
I came up with my first overclock today and wanted to share my results/settings with you and know if I have to change some settings and maybe some tips to go to 4ghz (I failed all my tests this far when going to 4ghz).
My specs are :
CPU : i7 930
Mother board : GIGABYTE X58A-UD5 rev 1.0
RAM : 3x2GB OCZ Platinum DDR3 2000mhz
Case : COOLER MASTER HAF 932
Ventirad : Noctua NH D14
BIOS Settings :
CPU Clock ratio : 21x
QPI Clock ratio : x36
Uncore clock ratio : x20
BCLK Freq : 181
SPD : 10.0
CPU Vcore voltage : 1.25 V
DRAM Voltage : 1.66 V
Everything else is in auto
RAM Timing is 9/9/9/30 and runs at 1810 Mhz so far.
I tryed to overclock to 4ghz with Vcore voltage up to 1.33v without success (BSOD after +10min in OCCT).
Using Vcore voltage at 1.23750V for 3.8ghz OC also get me a crash after +30min in OCCT.
What do you guys think ?
Thank you !
My specs are :
CPU : i7 930
BIOS Settings :
BCLK Freq : 181
SPD : 10.0
Thank you !
