Hi All,
First post here at OC and first foray into overclocking.
My problem is that I cannot get a 4ghz overclock to run a prime95 test for any longer than around 30 minutes before a BSOD, maximum temps I'm seeing after 30 minutes are 70 degrees. I've been at it for about a week now, updated the BIOS to the latest version and tinkered with some settings but just cant get it stable, so any help would be appreciated.
Here are my specs and OC settings, I hope I've included all the neccessary info.
i7 950
Gigabye GA-X58A-UD3R rev 2.0
Thermaltake Toughpower 750w psu
Thermalright Ultra 120 eXtreme CPU cooler
Corsair CMZ6GX3M3A2000C10 6GB 2000Mhz Triple Channel 10 10 10 27
OCZ Vertex 2 120GB SSD
WD 500GB HDD
Asus Direct cuII ENGTX570
Creative X-Fi Titanium Fatal1ty Pro
CPU Clock Ratio............................:20
CPU Frequency .....(Ghz)...................:4.0
Intel(R) Turbo Boost Tech..................:[Disabled]
CPU Cores Enabled..........................:[All]
CPU Multi Threading........................:[Enabled]
CPU Enhanced Halt (C1E)....................:[Disabled]
C3/C6/C7 State Support.....................:[Disabled]
CPU Thermal Monitor........................:[Enabled]
CPU EIST Function..........................:[Disabled]
Bi-Directional PROCHOT.....................:[Enabled]
Virtualization Technology..................:[Enabled]
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................:36
QPI Link Speed* ......................(Ghz):7.20
Uncore Clock Ratio.........................:x17
Uncore Frequency......................(Mhz):3,4
Isochronous Support........................:[Enabled]
Base Clock (BCLK) Control*.................:[Enabled]
BCLK Frequency (Mhz)*......................:200
PCI Exxpress Frequency (Mhz)...............:103
CPU Clock Drive (mV).......................:700
PCI Express Clock Drive (mV)..............:700
CPU Clock Skew (ps)........................:0
IOH Clock Skew (ps)........................:0
Performance Enhance........................:[Standard]
Extreme Memory Profile (X.M.P.)............:[Disabled]
System Memory Multiplier (SPD).............:x8
Memory Frequency (Mhz).....................:1,600
DRAM Timing Selectable (sPD) ..............:[Quick]
Channel A, B, and C Standard Timing Control
Cas Latency Time.............................:10
tRCD.........................................:10
tRP..........................................:10
tRAS.........................................:27
(All sub-timings on Auto for all 3 channels)
LoadLine Calibration.........................:[Level 2]
CPU Vcore....................................:1.325v
QPI/VTT Voltage..............................:1.275v
CPU PLL......................................: 1.80v
PCIE.........................................:1.50v
QPI PLL......................................:1.10v
IOH Core.....................................:1.10v
ICH I/O......................................:1.50v
ICH Core.....................................:1.10v
DRAM Voltage.................................:1.64v
DRAM Termination.............................:[Auto]
Ch-A Data Vref...............................:[Auto]
Ch-B Data Vref...............................:[Auto]
Ch-C Data VRef...............................:[Auto]
Ch-A Address Vref............................:[Auto]
Ch-B Address Vref............................:[Auto]
Ch-C Address VRef............................:[Auto]
Cheers
Jug
i7 950
WD 500GB HDD
Cheers
Jug
