- Aug 8, 2001
- Sunshine State, USA
- Thread Starter
- #21
Demont said:In 1024x768 it only shows 100hz and 120hz if I uncheck "Hide modes that this monitor cannot display"
That is very odd because even with my ti4600 I could run 120mhz at 1024x768 and it was not in the Hide mode that monitor cannot display, it was a supported resolution.
The P260 color monitors are designed to operate with system units or video adapters that generate a video output signal that falls within the specifications below:
Maximum addressability (pels): 1920 x 1440
Maximum pixel rate (Mpels/sec): 300
Horizontal frequency (kHz): 30 - 121
Vertical frequency (Hz): 50 - 160
When viewing a white background, two very thin horizontal lines may be visible across the screen. These lines are the faint shadows of the aperture grille damper wires and are characteristic of this technology. The monitor is not faulty.
Supported display modes are a function of the attaching system unit. The full range of display modes available with these monitors may not be available or supported with all combinations of system units, their operating systems, and application software.
File downloads (probably not needed)
http://www-3.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4VPS2T
PDF users guide (GOOD to read if you bought this)
http://www-3.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4FGPE7
