My dad got a replacement heat exchanger plate for the boiler at home but the old one isnt broken and i asked to keep it
i have cleaned it out and tested it using boiling and cold water and it seems to do what its supposed to do
in case you dont know a heat exchanger plate has two loops one is a hot loop and the other is a cold loop and it has several ridged copper plates, its used in boilers with the hot loop input being steam which condensed to a liquid by the cold loop which is then heated, its meant for liquid to liquid heat exchange
http://en.wikipedia.org/wiki/Plate_heat_exchanger
i have been trying to think of "novelle" ideas to implement this in computer cooling, here a few:
water chiller- by using both loops as one and covering the plate with undervolted peltiers and several copper heatsinks with delta fans, it may work as a chiller
or use it with a phase change, liquid freon in which takes heat from the water and vapourises
ultralarge waterblock- attach directly to cpu and cool heat exchanger plate with water
radiator-flow hot water through both loops and then use fans+heatsinks to cool the plate
just so you know, boiler grade heat exchanger plates cost around £70+ depending on where you get it from and industrial ones are around £300
