- Jun 18, 2001
- Winston Salem NC
Overclockers~
I ran across a pelt in my "big bin of goodies" I have no recollection of where this pelt came from, and there are no visible markings on the pelt it's self. I resently blew a Radeon 9600 pro in a heatsink removal job gone way way bad. (first time I broke anything) anyways I left the GPU water block in the loop as I plan on getting another 9600 pro or better. I thought now would be a good time to test this pelt out in the system. I took a spare 300 watt PSU and jumped the green to black so it would power on i then thrust the positive lead from the pelter into the yellow lead in a molex conector, I did the same for the ground (black to black)
Due to my lack of thermal testing equipment I am only able to tell you it has raised my CPU core 3 degrees.
I took a copper plate of a recently bought Barton 2500+ Stock heatsink (AMD doing something wierd here copper plate screwed to the bottom of alluminum heatsink) I then used some mounting parts from a thermaltake Vidcard heatpipe cooler and mounted the peltier to the Swiftech GPU waterblock. waterblock/copperplate/pelt
My question is: How can i tell what wattage this Pelter will handle, might it handle cooling a 9600 to 9800 pro?
after 2 hours I have a sinificant accumilation of ice on the cold side, but without a load on it I assume this is irrelevant.
Any Ideas?
Any Ideas?
